Lexmark W850 light prints
  • mascan42
    • 480
    I have a pair of these at the same customer with the same problem. The prints are light over the entire page, image is also light on the drum. The customer tells me they had this problem about a month ago also, and replaced the drum units which solved the problem for a short while but then it went back to light prints. I assume this is a toner supply issue, but I have trouble believing it would happen on two machines in the same office. What else could be happening?
    Re: Lexmark W850 light prints
    1) laser is dirty/failing
    2) compatible drums/toner
    3) transfer roller defective
    what have you done to fix?
    what are the page counts?
    any error displayed?
    do you have the manuals?
    • mascan42
      • 480
      1. Replacing the drum unit (including developer) temporarily solved the problem, so it's not that.
      2. They're using genuine toner & drums.
      3. The image is light on the drum, so it's not transfer.
      There aren't any codes, the meter can't be read because the menus are locked out by a password that the customer doesn't remember, and the manuals are completely unhelpful.
      Like I said, it's clearly a toner supply issue, since replacing developer solved it for a week or so before it started to degrade again, but I don't understand both machines having the same problem.
        Meter should be on config page...
        • mascan42
          • 480
          Doesn't matter. The reports menu is password locked.
            have you cold booted into Diag Mode?
            • mascan42
              • 480
              I'll try that, but I think we've slightly gotten off topic.
              • Woxner
                • Jul 2011
                • 833
                might be hv board. these failed a lot on lexmark.
                  Diag Mode allows you to check Bias readings etc.. I THINK you can print config/test pages also..
                  so not totally off topic..
                  and yes.. not on THIS model (for me) but similar models the HVPS and wires going to trans roller suck shit.
                  the Dell model (B6470?) of the Lex was KNOWN for the HVPS and harness failing.
                  if you don't have the manual .. PM me I do have it. ( besides tons more )
                  • Lance15
                    • Jun 2015
                    • 1082
                    7330
                    or
                    IBM InfoPrint 1985
                      Originally posted by Lance15
                      7330
                      or
                      IBM InfoPrint 1985
                      Not his model.. was a shitty drum/dev combo.. mono mfp type
                      • dalewb74
                        • Feb 2018
                        • 1125
                        given the age of the printers isn't it time for a new machine?
