XS796 error900 ( firmware ? )
  • malcolm godbold
    • Jun 2014
    • 1
    [Error Code] XS796 error900 ( firmware ? )
    I have the above on a XS796DTE at a customer where firmware updates are difficult. any ideas welcome
    • 23008
    Re: XS796 error900 ( firmware ? )
    What makes the firmware update difficult? =^..^=
    • Evoprintertech
      You need a firmware update. I had that happen on a cs 510. I forget the full update number but it had p70 in the version.
      I couldn't find the update on the web. It was a in house fix that lexmark had. You can contact lexmark and load the update on a usb. You are also going to need to monitor the printer for the next 2-3 after.
      • Lance15
        • Jun 2015
        • 1088
        900 errors are similar to 49 errors on HP's. If the unit is fine unplugged from the network or PC, then it's a corrupted print job somewhere.
        You can still upgrade the firmware, but, note that if the unit has an IPDS card or other accessory card, you'll need to contact Lexmark for the firmware. THAT firmware isn't posted on their website. I had to call them for a customer that had an IPDS card to get the correct firmware (Base, Network, IPDS).
        • dalewb74
          • Feb 2018
          • 1153
          i have seen this sometimes comes from someone trying to print coupons or stuff you general wouldn't print while at work.... if you can't update the firmware you might try a new print driver. but im leaning more towards the firmware like others have mentioned.
