I have a Bizhub c360 that is stuck in hour glass mode. I unplugged every option, usb, cat 5, adf, fax board and the HDD, I cleaned and re-seated memory Dimm and no change. I'm not even able to get into service mode. Is it the HDD? Any help would be appreciated.
Bizhub C360 stuck in hour glass mode
Re: Bizhub C360 stuck in hour glass mode
No, I haven't. I was contacted by the customer because the company that was out there prior, left the copier in that state and didn't return. I have access to firmware and service manuals,but I am not that familiar with Konica Minoltas,Comment
This is useally the firmware gone wacko if not it could be mfp or ssd board. but firmware fixes this most of the time.
Just copy the files from the folder to the usb root. dont worry about the ones outside the folder. nothing else should be on the drive. 2gb usb is recommended but 8 will workComment
Update the firmwareComment
Well, I updated the firmware ( AOEDOVO-FOOO-GD8-D1) the MFP said it downloaded it, I turned it off from control panel, then front door switch, unplugged from the wall, removed usb stick, powered back on and still the same result. I tried firmware (AOEDOVO-FOOO-GOO-D2) with the same results. I noticed there is an NVRAM firmware (AEDOVO-0023-G80-85) but was reluctent to try that one. Should my next step be to replace the MFP Board?Comment
When updating FW on this model, don't install scanner FW, it can kill the machineTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
I saved this procedure in case I have to use a used board sometime. I'm told it's the same procedure for all color machines, but need confirmation for this series.Precedure to fit a used MFP board Revision 6.pdfComment
Thank you all for the responses. I sent the MFP PWB out for repair and received word from the repair company that the board was the issue but they are unable to repair it basically because of irretrievable corrupted data. Now I have to discuss with the customer if they want to pay the price for a new one, they are not cheap!Comment
Try to get a junker. They are cheap these days and contain lots of other parts. At least that's what we are doing.
Hans“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.pngComment
