C224e Boot probleme
  • Firmaware
    • 30
    C224e Boot probleme
    Hallo folks,
    We have problems with a C224e. The Firmware was G20-M0 and original error was C-E302 by Scan to SMB. Printing', Copying .Scan to box. Scan to Usb-Stick: all ok.
    I went to xustomer site and my first idea was FW- upgrade. Great Bad idea. I wonna upgrade with GDR-M1 and by MFP-controller upgrade the result was N.G.. Since that, obviously boot not more. 2 /4 Columns.
    I'be tried an other HDD and with reset tool, but I've not the right one.
    What would you do...
    Thks in advance for your help
    Gesendet von meinem SM-G980F mit Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5805
    Re: C224e Boot probleme
    just load g20-M1 firmware, its the newest BASE FW
    let us know.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4632
      Make sure you put the M1 firmware or a few different USB drives and bring with you. These machines only like certain USB drives. The smaller the GB the better. I use a 2GB or 4GB Sandisk.
      If you don't have M1 FW post here and someone will send it to you
      • Gift
        • Mar 2011
        • 2458
        I also prefer sandisk drives - never had any problems with that brand.
        What's the voltage of the MFP board battery? One of my techs recently bricked an cxx4e with no service visits in ages after FW upodate and turning the machine off/on. Reset tool revived it partially and a new SSD board + reset tool did the trick in our case.
        • copier tech
          • 8132
          Originally posted by Firmaware
          Hallo folks,
          Try the LATEST firmware.
          Firmware Readme C224e C284e C364e GDR-M1.pdf
          โ€‹
          • Synthohol
            • 5805
            [ATTACH]51056[/ATTACH]
            He did!
            Thats what fucked it up to begin with.
            Always use base fw unless special fw addresses a particular issue then always base.
            Of it ain't broke, don't fix it
            • tsbservice
              Field tech
              • 7981
              Hallo folks,
              Did you tried new SSDB? It's relatively cheap.
              • Firmaware
                • 30
                I'll try with SSDB. With FW-Update the result it is always NG for MFP Controller.
                • copier tech
                  • 8132
                  Originally posted by Synthohol
                  He did!
                  G20-M0 is not the LATEST.
                  โ€‹
                  • Synthohol
                    • 5805
                    let us know.
                    never said it was the absolute newest, i said the latest BASE fw g20-m1
                    having a boot issue its recommended to flash the latest base fw then any special FW if needed
                    • femaster
                      • May 2011
                      • 1482
                      Nope, it's not, But the G20-M0 is what was on the machine. The firmware you suggested (GDR-M1) is what they had attempted to update to. They had already done what you suggested, before you suggested it, and that is why the copier no longer works.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4632
                        Speaking of firmware and sorry to get off topic. Don't think I could ever get an answer to this question, even from instructors at Kon/Min school. Think I may have asked on this forum before?
                        Here's the question:
                        Does the latest "special" f/w have all the prior "fixes" on it along with new issue f/w?
                        • femaster
                          • May 2011
                          • 1482
                          I wish I could answer this for you. It is a question I've been wanting to know the answer to for a long time as well.
                          • Synthohol
                            • 5805
                            All those details are in the Readme docs
                            Just takes time reading through them
                            • tsbservice
                              Field tech
                              • 7981
                              I may respectfully disagree with you this time. It's not documented not we have definite answer from KM. And I take my time to read through all hundreds fixed issues.
