Hi,
I am dealing with a bizhub 224e showing c2564 over and over.
It has 170k. Started to print with lower density. Another tech went and saw the drum with a scratch and low developer so he assume the drum was the cause. He came back day later with dv512k and dr512k, both oem and new, that works for a couple of days an then came the same problem. Then came back with the hoper section and toner but the machine start to show the c2564 code and 0.0% tcr ratio. Manual add toner wont change a bit that tcr ratio.
Now the machine is in the shop and I have to deal with it.
allready swap another hoper, the FRB, dv unit and dr unit. All this taken of a working machine.
changed new chips for Dv and Dr units with out succes. uploaded firmware also with out succes.
machine starts, do the warming and then came with the code. If I run the reset some times I can even print the counter or the test and then get the code. Besides the light grey color the test and counters looks great.
With costumer the machine was on oem toner, the second toner was katun (due the lack of oem). This katun is almost full so I dont think is toner problem.
Searched in the forum and only two treads with this code, but not the same issue. Searched also for 0.0 tcr on the forum but after several read I dont see any tread that could help (maybe because I was all day with the same machine)
Only step I have not performed as stated on the manual is PRCB. Does any one of you guys has ever come with something like this?
thanks in advance
thanks in advance
