Doc feeder J6633
  • kenpio
    • Dec 2015
    • 198
    [Jamming] Doc feeder J6633
    Good morning,
    Have a C450i that is jamming in the doc feeder. It does not even have over 100k on it. I go to the test mode and run the paper passage, put a stack in and press start. It starts pull in paper in and it is going and all of a sudden a KLUNK and a J6633. I have cleaned all the sensors in the path and there is no reason that I can see why it does this. It could be at the beginning of the stack and then I think it s going all the way through and then KLUNK!!! I have tested the sensors and they are good. Just one of those things. Any input would be swell!!!
    KEN
  • 4Toon
    • Mar 2023
    • 105
    Re: Doc feeder J6633
    Can you pull the paper through the DP or does it catch? I would do a sensor check and manual flag sensors and make sure they are all turning on and off. The turn over sensor has had alot of issues for me in the past
    • allan
      RTFM!!
      • 5459
      Check tension on the belts at the back.
      Whatever
      • kenpio
        • Dec 2015
        • 198
        Yea you can pull the paper through, there are no tick on the paper. I did "adjust" the post that holds the cover down. I have had trouble with those. Yea pretty much the paper is laying in the feed section and then pull the paper out the exit. I will check the belts and sensors.
        THanks
        KEN
        • Synthohol
          Certified Konica Expert
          • 5738
          judging just by the noise you describe it sounds like a wayward paperclip riding on a belt and locks up on a gear.
          thats my guess final answer
          • Woxner
            • Jul 2011
            • 829
            If you dont find a paper clip check the frame for gear drive on top door. There is a bulliten on this.
            • 4Toon
              • Mar 2023
              • 105
              THanks
              KEN
              If the paper makes it all the way around the bend and you pull it out the bottom or the exit like you said I would bring a turn over optical sensor with you when you go.
              • kenpio
                • Dec 2015
                • 198
                Looking on KM and where is this bulletin. I know it is a labyrinth of info. Just a hint please.
