it does not stop feeding toner, since the tcr reading is very low 2
change
imaging unit M(x2)
PRCB
PHRYB
The lines of the connector of the unit to the PHRYB give continuity...
I even put unit C in position M, exchanging the chips... and I have the same result, the TCR reading M 2% (unit C)
I think the problem is the T/C ratio detection, because this value can be affected?
Today I will try the initialization clear all data and update the firmware.
I run out of ideas
change
imaging unit M(x2)
PRCB
PHRYB
I run out of ideas
