7145 Fuser Same As?
  • mrfuser
    • 1603
    7145 Fuser Same As?
    Does anyone know if there is another Konica that has the same fuser as the 7145? Maybe even close with the same rollers and lamps?
    kelly
  • jobert
    • Jan 2011
    • 49
    I think 7130,7135,7020 and 7030..Im not so sure but it has the same fuser assy..Try to look for the part number..
    • copytechman
      • Nov 2008
      • 926
      According to my parts catalog although it's basic frame is very much like a 7222-7235 series fuser, certain key parts may differ, lamps from 7145 and 7222 series appear to correspond to each other and I use the same thermistor set from 7022 all the way to the 7145.. 7022-7135 use lamps that correspond to each other as well.. fusing roller is definitely different tho on the 7145 from that to a 7222, (7145 is beefier). Not sure what else tho without doing a complete cross reference... harness ends and frame keys can differ as well.
      Regards!
      A.
      • SmellsHot
        Head Tech
        • 512
        7135 fusing rollers will work, have to use 7145 web assy, or just replace the cleaning roller and web within, with 7020 stuff. The unit itself is different, not swappable with anything else. everything else you can use from the 7020-7235.
        Everyone has the right to be stupid. Some people just abuse this privelage more than others
