The random thought thread
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    #451
    Re: The random thought thread
    Originally posted by CompyTech
    No, but I've had them fly up and hit me in the nose before. Usually to bounce off somewhere to oblivion.
    Sent from my Nexus 7 using Tapatalk
    Once you get the end of your flat tip on it, drape a paper towel or rag over it before prying. Has saved me a lot of floor time on my hands and knees.
    • habik
      • 2013
      #452
      I think I may be able to develop a tool for C-clips. How many of you would be interested?
      Sent from my iDon't believe in marketing device using Tapatalk
      Firmwares HERE
        • 37480
        #453
        Originally posted by Phrag
        *Jesus Clips.
        Fixed those errors in the last 3 posts for you. I magnetized my precision flat heads, and needle nose pliers. Reduces Jesus Clip Launches 10 fold, and makes them easier to put back on.
        Does anybody use safety glasses when removing them?
        I try to make sure that I am positioned to where they o away from my body. Of course that means if they do go flying it is across the room never to be seen again.
        • KapeKopyTek
          • Nov 2013
          • 284
          #454
          You drop a screw, or an e-clip launches, etc., and it can land one of two ways - right there in plain view where you hardly have to move to find it, or never to be found no matter how hard you look. Good Bounce, Bad Bounce. My kids can read me when I get home - "Bad Bounce day today, Dad?" Also have a tackle box of spare screws, clips, rings, charge terminals, etc. At least if it takes a bad bounce, I have a solid chance of having a replacement.
            • 37480
            #455
            With a dropped screw I always try to find it or at least make sure that it has not landed where it can short out a board go get caught in gears.
            • NeoMatrix
              Senior Tech.
              • 3513
              #456
              Re. E-Clip tool :
              They have already been invented. I've had one for years. They come in handy at times. I've saved my self some major hours of re-work by being able to use the extension between narrow openings/gears and covers to re-fit forgotten E-clips.
              See the attached image. The E-clip removal point of this tool has a retainer tab broken off but it still works fine, you just have to hold the e-clip with your finger when extracting. The refit side works well to this day. This tool is nearly 30 years old.
              • KapeKopyTek
                • Nov 2013
                • 284
                #457
                If I'm working on top of the machine (where I try to do most of my work, at my knees insistance), I close as many covers as possible. I try to find all my lost items as well, if I think it might be around a board or moving parts, I'll dig a little harder, maybe even try to shake the machine, but sometimes you just can't find 'em, in which case a spare is a nice thing to have.
                • Zeldaman
                  • Mar 2011
                  • 946
                  #458
                  • HenryT2
                    • 962
                    #459
                    Re. E-Clip tool :
                    [ATTACH=CONFIG]27370[/ATTACH]
                    I remember those ... we even had one ( used on typewriters mostly ) that had a holder for the E-Clip and it had a button on top to press that pushed the clip on. No hook to remove the clip though.
                    The sad thing is that now a lot of these clips are made of nylon/plastic and do not fit into a tool like this due to a small tab on them . Some of these can be removed and re-installed with forceps .
                    "The Serenity Prayer" . . .
                    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
                      • 23007
                      #460
                      Yeah, the hemostats work nicely on the plastic ones. But since they're non-ferrous the magnet isn't of much use if you drop it.
                      I'd be interested in seeing what you have in mind. I've developed a few tools myself and the idea alone is enough. While you're at it can you develop a plastic magnet? =^..^=
                        • 23007
                        #461
                        I had on of those E-clips get away from me yesterday. I was working on top of two metal file cabinets. There was no place for it to hide ... excepting the 0.5mm gap between the file cabinets, and they sure were heavy. =^..^=
                        Hahaa. That's what I refer to as a "Murphy". If there is a million to one chance it could happen --"Murphy's Law say's it will."
                        I've thought about writing a book on my experiences with "Murphy's Law"...
                        I couldn't have gotten the clip to stand on end in that exact spot in a millions years ... that must be why it happened. =^..^=
                        • habik
                          • 2013
                          #462
                          didn't know that C or E clip remover/inserter was already invented - made I like the simplicity of the design in previous picture. I had in mind a type of bend nose pliers or calliper/mastic gun / wire stripper mechanism application. But it seems overcomplicated comparing to the existing one.
                          I think I'll try to make a prototype over christmas time extended holiday
                          Plastic magnet/attract tool exists "Well processed blue tag at the end of a screw driver" or piece of two-sided tape tape always works .
                          Firmwares HERE
                          • Iowatech
                            Not a service manager
                            • 3930
                            #463
                            Two downsides with the tool pictured earlier are that it requires a clear line of sight to the clip for the entire length of the tool, and the thin flat piece will bend rather easily if you are not at total peace with all of the world.
                            I've wrecked at least three of those, and the latter downside is what usually dooms that type of tool in my experience.
                              • 23007
                              #464
                              How about this for a preliminary mockup?
                                • 37480
                                #465
                                Double sided tape works fairly well.
