Network tab missing after adding Fax and disable DHCP on Bizhub C353
  • NewGeek
    • May 2019
    • 17
    #16
    Re: Network tab missing after adding Fax and disable DHCP on Bizhub C353
    Originally posted by copyman
    Agree with mincopier, sounds like time to initialize machine. I would also do a "logical" format of the hdd.
    How do I do a logical format?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      #17
      Procedure (Logical Format (only when set up with HDD replacement))
      1. Call the Service Mode to the screen.
      2. Touch these keys in this order: [State Confirmation] -> [Memory / HDD Adj.] -> [HDD Format].
      3. Touch [Logical Format].
      4. Press the Start key to start the formatting sequence.
      5. The sequence will be automatically terminated as it is completed.
      6. Turn off the main power switch and turn it on again more than 10 seconds after.
      * Formatting the hard disk will erase all data contained in it.
      NOTE
      • As HDD formatting deletes Movie data, Voice data, OCR dictionary data, PDF/A font, and OCR font, and Unicode font you need
      to reinstall these data as necessary after using this function.
      • NewGeek
        • May 2019
        • 17
        #18
        NOTE
        Thank you, Do i need any of that for the basic use in our org?
          • 30279
          #19
          If you don't have the firmware DON"T format the harddrive of you will get message to install on screen
          ARP request will time out do not connect network cable, than enter ipaddress manual
          • NewGeek
            • May 2019
            • 17
            #20
            (Number 5) Network option in administrator is missing and it is also missing from service mode, where can I put in a IP address?
              • 30279
              #21
              Have you into service mode and initialized the network setting data.
              • NewGeek
                • May 2019
                • 17
                #22
                [ATTACH=CONFIG]42924[/ATTACH]
                OMG! Thank YOU! This is what I have done, and network shows up!!! I will go ahead and do test prints and scanning and keep you posted, but just the fact that a network option reappeared ob the screen is a big step
                This is my mac address 00-20-6b-61-d1-61
                C:\WINDOWS\system32>arp -a
                Interface: 192.168.1.10 --- 0x2
                Internet Address Physical Address Type
                192.168.1.1 9c-3d-cf-b7-43-00 dynamic
                192.168.1.13 d4-be-d9-e3-e8-22 dynamic
                192.168.1.222 00-20-6b-61-d1-61 static
                192.168.1.255 ff-ff-ff-ff-ff-ff static
                224.0.0.22 01-00-5e-00-00-16 static
                224.0.0.251 01-00-5e-00-00-fb static
                224.0.0.252 01-00-5e-00-00-fc static
                239.255.255.250 01-00-5e-7f-ff-fa static
                255.255.255.255 ff-ff-ff-ff-ff-ff static
                C:\WINDOWS\system32>arp-s 192.168.1.222 00-20-6b-61-d1-61
                'arp-s' is not recognized as an internal or external command,
                operable program or batch file.
                C:\WINDOWS\system32>arp -s 192.168.1.222 00-20-6b-61-d1-61
                192.168.1.3 1c-c1-de-56-2e-af dynamic
                C:\WINDOWS\system32>ping 192.168.1.222-t
                Ping request could not find host 192.168.1.222-t. Please check the name and try again.
                Pinging 192.168.1.222 with 32 bytes of data:
                Request timed out.
                Reply from 192.168.1.222: bytes=32 time=1ms TTL=64
                Reply from 192.168.1.222: bytes=32 time<1ms TTL=64
                Ping statistics for 192.168.1.222:
                Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
                Approximate round trip times in milli-seconds:
                Minimum = 0ms, Maximum = 1ms, Average = 0ms
                • allan
                  RTFM!!
                  • 5462
                  #23
                  C:\Users\Y> ARP -s 192.168.1.222 00:20:6B:61:d1:61
                  The ARP entry addition failed: The requested operation requires elevation.
                  C:\Users\Y>ARP -s 192.168.1.222 00:20:6B:61:d1:61
                  C:\Users\Y>ARP-s 192.168.1.222 00:20:6B:61:d1:61
                  'ARP-s' is not recognized as an internal or external command,
                  Goto windows search and type cmd then on cmd.exe right click and select run as administrator.
                  Whatever
                  • NewGeek
                    • May 2019
                    • 17
                    #24
                    I'd like to save the complete PDF, anyone have it?
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      #25
                      Well, that one is for the C352 which is not the same model as your C353 so you wouldn't really want it anyway. Those solutions files are supposed to be only for qualified technicians anyway.
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • NewGeek
                        • May 2019
                        • 17
                        #26
                        Request timed out.
                        I ran in to the same issue now AGAIN!
                        But this time it is telling me that access is denied even though I am running it as administrator. when I try it not running it as admin it says
                        The ARP entry addition failed: Access is denied.
                        • rrrohan
                          • Sep 2011
                          • 1977
                          #27
                          when you initially got it working did u leave it on DHCP or set it statically? I would suggest set it static
                          also if you set a manual arp record of 192.168.1.222 you shouldn't need to re do it unless you got a new PC
                          do
                          Code:
                          ARP -A
                          if it still exists no need to re create it
                          I wonder if this is why the previous owners gave it away to you for free, constant network issues.
                          dont recall if these have a battery on the main MFP Board. maybe its flat if there is one
                          • NewGeek
                            • May 2019
                            • 17
                            #28
                            I am getting the error, access is denied
                            Interface: 192.168.1.6 --- 0x2
                            192.168.1.9 ee-08-6b-81-26-2a dynamic
                            192.168.1.12 d4-be-d9-e3-e8-22 dynamic
                            C:\WINDOWS\system32>arp -s 192.168.1.255 00-20-6b-61-d1-61
                            • Synthohol
                              Certified Konica Expert
                              • 5843
                              #29
                              if the network tab is showing up why arp it?
                              just change it through the CP
                              plus you cant use .255 .254 is the last usable octet
