Network tab missing after adding Fax and disable DHCP on Bizhub C353
Re: Network tab missing after adding Fax and disable DHCP on Bizhub C353
Procedure (Logical Format (only when set up with HDD replacement))
1. Call the Service Mode to the screen.
2. Touch these keys in this order: [State Confirmation] -> [Memory / HDD Adj.] -> [HDD Format].
3. Touch [Logical Format].
4. Press the Start key to start the formatting sequence.
5. The sequence will be automatically terminated as it is completed.
6. Turn off the main power switch and turn it on again more than 10 seconds after.
* Formatting the hard disk will erase all data contained in it.
NOTE
• As HDD formatting deletes Movie data, Voice data, OCR dictionary data, PDF/A font, and OCR font, and Unicode font you need
to reinstall these data as necessary after using this function.Comment
* Formatting the hard disk will erase all data contained in it.Comment
If you don't have the firmware DON"T format the harddrive of you will get message to install on screen
ARP request will time out do not connect network cable, than enter ipaddress manualComment
(Number 5) Network option in administrator is missing and it is also missing from service mode, where can I put in a IP address?Comment
c352 network tab.jpgComment
This is my mac address 00-20-6b-61-d1-61
C:\WINDOWS\system32>arp -a
Interface: 192.168.1.10 --- 0x2
Internet Address Physical Address Type
192.168.1.1 9c-3d-cf-b7-43-00 dynamic
192.168.1.13 d4-be-d9-e3-e8-22 dynamic
192.168.1.222 00-20-6b-61-d1-61 static
192.168.1.255 ff-ff-ff-ff-ff-ff static
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
239.255.255.250 01-00-5e-7f-ff-fa static
255.255.255.255 ff-ff-ff-ff-ff-ff static
C:\WINDOWS\system32>arp-s 192.168.1.222 00-20-6b-61-d1-61
'arp-s' is not recognized as an internal or external command,
operable program or batch file.
C:\WINDOWS\system32>arp -s 192.168.1.222 00-20-6b-61-d1-61
192.168.1.3 1c-c1-de-56-2e-af dynamic
C:\WINDOWS\system32>ping 192.168.1.222-t
Ping request could not find host 192.168.1.222-t. Please check the name and try again.
Pinging 192.168.1.222 with 32 bytes of data:
Request timed out.
Reply from 192.168.1.222: bytes=32 time=1ms TTL=64
Reply from 192.168.1.222: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.222:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\WINDOWS\system32>Comment
C:\Users\Y> ARP -s 192.168.1.222 00:20:6B:61:d1:61
The ARP entry addition failed: The requested operation requires elevation.
C:\Users\Y>ARP -s 192.168.1.222 00:20:6B:61:d1:61
C:\Users\Y>ARP-s 192.168.1.222 00:20:6B:61:d1:61
'ARP-s' is not recognized as an internal or external command,
operable program or batch file.WhateverComment
Well, that one is for the C352 which is not the same model as your C353 so you wouldn't really want it anyway. Those solutions files are supposed to be only for qualified technicians anyway.Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.Comment
OMG! Thank YOU! This is what I have done, and network shows up!!! I will go ahead and do test prints and scanning and keep you posted, but just the fact that a network option reappeared ob the screen is a big step
Request timed out.
But this time it is telling me that access is denied even though I am running it as administrator. when I try it not running it as admin it says
The ARP entry addition failed: Access is denied.Comment
when you initially got it working did u leave it on DHCP or set it statically? I would suggest set it static
also if you set a manual arp record of 192.168.1.222 you shouldn't need to re do it unless you got a new PC
doCode:ARP -A
I wonder if this is why the previous owners gave it away to you for free, constant network issues.
dont recall if these have a battery on the main MFP Board. maybe its flat if there is oneComment
I am getting the error, access is denied
Interface: 192.168.1.6 --- 0x2
192.168.1.9 ee-08-6b-81-26-2a dynamic
192.168.1.12 d4-be-d9-e3-e8-22 dynamic
C:\WINDOWS\system32>arp -s 192.168.1.255 00-20-6b-61-d1-61
if the network tab is showing up why arp it?
just change it through the CP
plus you cant use .255 .254 is the last usable octetWe know a thing or two because we've seen a thing or two.
The medication helps though...Comment
