Ricoh IMC6500 scan to email using gmail
  • dalewb74
    • Feb 2018
    • 1167
    i have a ricoh imc6500 that won't scan to email using gmail. i have input all of the gmail server settings into the email settings of the ricoh. in gmail i have setup the 2fa for security. it has generated the 16-digit password. when i go back to my ricoh under email server settings. i can input all settings except the password. when i put in the password i get the error: wrong parameter. reset the correct parameter. per ricoh support, they said don't copy and paste the password. we have typed the password in and still get the same error. has anyone ran into this and found a fix? there was a firmware release at the end of last month. i am going to try that to see if it will resolve the issue. thanks for your help.
  • kingarthur
    • 1385
    I'm not sure if it's the same with Ricoh, but in the KM devices, the email address goes where the device name goes, the box that says "email address" stays blank
    • copytechtrouble
      • Nov 2020
      • 112
      so you got an App Password from google?
      the app password is displayed with spaces in between every 4 characters to make it easier to read but the spaces are not part of the password. maybe that is your issue?
      • dalewb74
        • Feb 2018
        • 1167
        yes i have the 16 digit app password. but every time i try to add it into the ricoh settings for the email server settings i get the error message.
        wrong parameter
        reset the parameter
        im working with the customers IT dept.. and he finally got it to take the password. though i don't know what he did. but now he doesn't know where it goes to, it sends without an error. but doesn't appear on the receiving end. but i believe that would just an issue with the path/ email address. though i just thought about it. google might be blocking it. i probably need to add a generic subject line. i know gmail will block it thinking it is spam.
        • ridgemill
          • Sep 2017
          • 192
          Copy and paste the password into Notepad, you might be copying stray Unicode characters, these will get removed (if Notepad is set to ASCII) or show up as random characters.
          Or, type it in manually in Settings instead of the web manager.
          Just tested entering Unicode into the password field, and it fails with: Wrong parameter. Reset the correct parameter
          • dalewb74
            • Feb 2018
            • 1167
            i did type it, but that failed as well. i am waiting for a response. i am working with the customers IT department. and apparently, he did something that finally took the password. i am not sure, i am thinking something was missed before. once it was fixed it allowed the password. currently it seems to send the email. but it doesn't, for whatever reason, arrive at its destination. i am thinking the destination path is incorrect. or i know gmail will also block emails if it doesn't have a subject line. so i advised the IT guy to create a generic subject line for all emails. i generally just put in the subject line ..... from customer name.
              • 37587
              At one time Google and many others used to block email if the sender domain was different from the authentication domain.
              • ThisPete
                Snr/troubleshoot/network
                • Jun 2014
                • 244
                I've had problems with scanning to email on Konica Minolta's in the past if nothing was in the 'body' of the email, just a thought.. 🤷‍♂️
                • dalewb74
                  • Feb 2018
                  • 1167
                  thanks slim. i will check.
                  • dalewb74
                    • Feb 2018
                    • 1167
                    can you add a line to the body? i thought that was just the document that was scanned? i can add to the subject line.
                    • dalewb74
                      • Feb 2018
                      • 1167
                      ok i misunderstood the IT guy. for whatever reason it will not take the password under the email settings. still get the error:
                      wrong parameter
                      password
                      have tried copy and paste. and also tried just typing it out. and get the same error each time.
                      • dalewb74
                        • Feb 2018
                        • 1167
                        i did get a reply slim. the domains are both the same.
                        • dalewb74
                          • Feb 2018
                          • 1167
                          still haven't figured this one out yet. was able to get the customer to scan to pc folder instead of to email when using gmail as the email server.
