Canon C3530i
  • copytech,mike
    CopyTech,MIKE
    • Jun 2014
    • 254
    [CQ] Canon C3530i
    1/2 inch black/grey band across the copy even when in single color mode such as all yellow copy and even with blank sheet of paper on glass. Has new black drum. I just can see how its the transfer belt when im not asking for black at all.
    Re: Canon C3530i
    examples?
    • copytech,mike
      CopyTech,MIKE
      • Jun 2014
      • 254
      Re: Canon C3530i
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Re: Canon C3530i
        Does it do it on test print page
        Regards Mark
          Re: Canon C3530i
          [ATTACH=CONFIG]49215[/ATTACH]
          LEF or SEF?
          • copytech,mike
            CopyTech,MIKE
            • Jun 2014
            • 254
            Re: Canon C3530i
            It does it on test print page and also does it with a blank sheet of paper on the glass. This site wont let me upload another sample. Not sure why. You can make a single color all yellow copy and it will still put that black/grey band across the copy. It will even put the grey stripe on your copy with the black laser blocked off.
            • 20 year tech
              • May 2014
              • 577
              Re: Canon C3530i
              The sample you show looks like the shading correction adjustment sheet. Did you try doing a shading correction before this issue started ?
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 254
                Re: Canon C3530i
                No i didnt do a shading correction. I wil try to upload another sample. Keep getting upload failed message.
                  • 22934
                  Re: Canon C3530i
                  So the next thing to determine is, what color is it really? K: black or composite black? If its K: black, I'd look at black imaging components. BUT, I suspect that it's composite black, which means that the primary transfer belt is probably not cleaning. You should be able to pull the primary transfer belt at any time and see the residue on the belt. =^..^=
                    Re: Canon C3530i
                    I was thinking composite also since he said he can see color separation
                    • copytech,mike
                      CopyTech,MIKE
                      • Jun 2014
                      • 254
                      Re: Canon C3530i
                      The test chart is all black. I just told the machine to give me all yellow. Your right i think. I suspect the belt is bad. Replaced cleaning unit and still get residue on the trans belt. Its a very flimsy transfer belt unit. This model is junk. Heres a better sample. It simply shouldnt have any black on this copy. IMG_20210521_0001_NEW.jpg
                        Re: Canon C3530i
                        sounds like the images you are trying to upload are too large
                        again I ask is it LEF or SEF?
                        • copytech,mike
                          CopyTech,MIKE
                          • Jun 2014
                          • 254
                          Re: Canon C3530i
                          Yes. The test chart is all black. Here it is when i told it to do yellow.IMG_20210521_0001_NEW.jpg Point im making is that theres no way you should be getting a black line when your making an all yellow copy in single color mode. You shouldnt get a black line when your making a blank copy either. You can get a solid black copy if your blk laser is stuck on but thats not the case. You can also block the laser path for black and you should get an all blank copy. Not a black line. (No laser to write on the drum. Are you with now?
                          • copytech,mike
                            CopyTech,MIKE
                            • Jun 2014
                            • 254
                            Re: Canon C3530i
                            Single color mode. You should not be getting a trace of black while in single color mode.
                            • copytech,mike
                              CopyTech,MIKE
                              • Jun 2014
                              • 254
                              Re: Canon C3530i
                              Thanks Phil
