iR6000 left deck motor cannot rotate (M5)
  • Peter Sim
    • Sep 2008
    • 445
    Hai all ,
    Need help and advice.
    Problem:
    1) left deck lifter cannot lift up
    Check:
    1) sensor PS9,PS10,PS20 comfirm ok under I/O display IO-P02/P03
    2) sensor PS49,PS50 -ok
    3) there is on signal on M5 under I/O display IO-P10-bit0
    4) i cannot comfirm whether PS20 is ok or not
    Please help.
    Thanks in advance.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Originally posted by Peter Sim
    Hai all ,
    Problem:
    Check:
    Please help.
    Thanks in advance.
    Did you try parts check in service for M5. Also check wire harness and connector pins.
    What are the jam codes. Is your right deck workiing?
      • 23002
      When these Canon paper decks have any kind of a lift error the motor operation just times out after so many seconds. The first thing to do is just turn the machine Off/On and see if it will try to lift again.
      • teckat
        • 16083
        Hai all ,
        Problem:
        Check:
        Please help.
        Thanks in advance.
        Right Deck (M5) and Left Deck (M4) lifter motor on the DC controller at J105, Pin 13 and J105, Pin 12
        information in the Service Manual is incorrect. The voltage should read 0 volts until the Paper Deck is inserted into the copier, when it should read about 3.9 volts as the lifter motor is lifting the paper.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          That's true. Another simple thing do is to look behind the deck and make sure there is no paper stuck.
          • Peter Sim
            • Sep 2008
            • 445
            Thank you teckat, SCREWTAPE,blackcatand for all your valuable reply.
            For teckat,from your clue, i found out the motor driver pcb board pico fuse(FU2105) and i change but alway blown.I guess is the M4 motor problem and need to comfirm
            by changing the M4 motor.
            • Peter Sim
              • Sep 2008
              • 445
              Is comfirm M4 motor spoilt.
              Thank you.
              • Zela
                • Mar 2014
                • 25
                Re: iR6000 left deck motor cannot rotate (M5)
                hello everyone
                Today I have the same problem but nothing helped.
                Work performed:
                1) new motor M4,5
                2) new motor driver pcb
                3) other DC controler
                4) other dc power supply
                5) other feed unit
                6) other JUMBO
                please help
                • teckat
                  • 16083
                  Originally posted by Zela
                  hello everyone
                  Work performed:
                  1) new motor M4,5
                  5) other feed unit
                  6) other JUMBO
                  please help
                  • Zela
                    • Mar 2014
                    • 25
                    The machine we are transported to repair the company and the same result.
                    Power supply to the machine is 240V.
                    Power source is 24V.
                    After closing the paper deck to 3,9V discovery motor,
                    but the motor will not start even though it is new.
