canon 2270 fuser film tears
  • pramod
    • Jul 2010
    • 21
    [Misc] canon 2270 fuser film tears
    I m facing problem in canon ir 2270 fuser teflon film slips rear side and gets torn within 2 to 3 days.
    I had replaced lower roller and side bushings also. if any one knows solution please reply
    Thank You
  • shazza
    • Nov 2009
    • 96
    Hi,
    Check that the Fixing assy drive moter meshes with fixing assy gear may need ti adjust bracket assy
    Shazza
    • teckat
      • 16083
      Thank You
      replace the Pressure Roller (FC5-7245-000) with the new style Pressure Roller (FC5-7207-010). The color of the old Pressure Roller is brown and the new Pressure Roller is black.
      • nallard84
        • May 2010
        • 26
        I concur with tech kat, Been replacing these rollers like they are free, also there is a new actuator for the door that applies the pressure to the actuator on the fuser assembly. The old style is trrait at the end of the metal where the new style has a slight bend.
        • apollo
          • Mar 2008
          • 182
          Also make sure the copier is level, will have to use small spirit level and level the four stabilising legs to adjust level.
          #I this problem tearing film as the copier was not level and film sliding one side and tearing.
          • pramod
            • Jul 2010
            • 21
            Thanks Everyone for reply,
            I had tried all the remedies suggested by all of you ,but there is a same problem.
            I even interchanged whole Fuser assembly, problem is persist in same machine,faulty unit is working properly in another machine.
            Thanks for suggestion ,if any other solution please reply
            • teckat
              • 16083
              The only two common denominators left are Fix Drive Unit & Seating position>
              One last suggestion is / make sure the FIXING DELIVERY DRIVE ASSEMBLY is the correct one there are two different ones for this series models>
              FM2-0242-000=iR2270/iR2270F/iR2870/iR2870F
              iR2230/iR2230F/iR2830
              FM2-1771-000=iR4570/iR4570F/iR3570/iR3570F
              iR3530/iR4530
              Connections are the same, difference is on two gears
              FU5-0095-000
              1 GEAR, 17T/103T= iR2270/iR2270F/iR2870/iR2870F
              FU5-0126-000
              1 GEAR, 21T= iR2270/iR2270F/iR2870/iR2870F
              FU6-0019-000
              1 GEAR, 24T/103T iR4570/iR4570F/iR3570/iR3570F
              iR3530/iR4530
              FU6-0020-000
              1 GEAR, 24T iR4570/iR4570F/iR3570/iR3570F
              iR3530/iR4530
              • omkalse
                • Sep 2011
                • 2
                Re: canon 2270 fuser film tears
                I have also same problem with my machine. But it's bootrom changed from IR3570 to IR4570. Is there any remedy for that.
