canon D-880 prints ok/ blank copies when copying
  • tmaze01
    • Oct 2010
    • 76
    [CQ] canon D-880 prints ok/ blank copies when copying
    hi, i have this problem machine that seems to have one issue after another
    a couple weeks ago i posted a problem with a canon D 880 having no display
    with your help it was fixed (problem was on the main board there is a simm
    chip that looks like a laptop memory took it out and reinserted and problem was fixed
    I THANK YOU AGAIN)
    now it prints ,,,, but i get no image when using adf or on glass
    any help on this is appreciated ,AND AS ALWAYS THANKS IN ADVANCE.
  • gbsys
    Re: canon D-880 prints ok/ blank copies when copying
    I THANK YOU AGAIN)
    Try replacing the data cable to the scanner.
      • 23009
      Take a look at the laser shutter. If the shutter doesn't open, blank image. =^..^=
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Read again carefully.
        click...
          • 23009
          Originally posted by zoraldinho
          [ATTACH=CONFIG]13030[/ATTACH]
          I wish I could do that ...
