Canon IR 6000
  • ar6565
    • 94
    [CQ] Canon IR 6000
    Thin hairy black line when printing form the computer only, but when copying from the copier glass or ADF there is no lines and the copy is good.
  • canonbundy
    • Jun 2012
    • 607
    Re: Canon IR 6000
    Remove the Drum Unit, inspect the Drum for scratches, vacout the cleaner & the Sep Claws etc, flip the Cleaning Blade should be ok.
    • Canuck
      Tech Specialist
      • 1713
      Re: Canon IR 6000
      LTR or LTRR
        • 23009
        Re: Canon IR 6000
        Originally posted by Canuck
        LTR or LTRR
        That was my question. If LTR-R then it's the fuser. =^..^=
        • ar6565
          • 94
          Re: Canon IR 6000
          It is A4 paper
          • Canuck
            Tech Specialist
            • 1713
            Re: Canon IR 6000
            Ok then....A4 ...not A4R...need this clarified. Have you polished the drum? From what you are saying, the lines run front to rear of the copier...not in paper feed direction
            • ar6565
              • 94
              Re: Canon IR 6000
              A4 & A4R .
              Never polish the drum
              Yes, the lines run front to rear of the PRINT direction not copy direction (when I copy there is no lines at all)
              NOTE: These lines comes before the paper goes the the fuser unit
              Thanks for help
                • 23009
                Re: Canon IR 6000
                What Canuck is trying to qualify, is what direction the lines are appearing: feed direction or crossfeed. Four posts and I still don't know. =^..^=
                • songela
                  • Mar 2008
                  • 216
                  Re: Canon IR 6000
                  Change the file format and see the results, i.e. if you it is PDF file, try TIFF, WORD, EXCEL or something else, observe and report back.
                  • ar6565
                    • 94
                    Re: Canon IR 6000
                    Thanks very mauch
                    it's the feed direction
                    • Canuck
                      Tech Specialist
                      • 1713
                      Re: Canon IR 6000
                      One post says front to rear,another says paper feed direction. THE SAMPLE THAT YOU DISPLAYED,IS IT A4 OR A4R? Last chance man
                        • 23009
                        Re: Canon IR 6000
                        Check the fuser first. I really doubt that this is some sort of image processing issue.
                        Most likely you just didn't notice it on copies, or the prints have more fill, making the lines more visible. =^..^=
                        • ar6565
                          • 94
                          Re: Canon IR 6000
                          A4R
                          • Canuck
                            Tech Specialist
                            • 1713
                            Re: Canon IR 6000
                            Copy sample posted.....off glass or through document feeder?
                            • ar6565
                              • 94
                              Re: Canon IR 6000
                              when I copy from the glass and ADF it is very good
                              the problem when I print form the computer WORD EXCEL PDF
