Thin hairy black line when printing form the computer only, but when copying from the copier glass or ADF there is no lines and the copy is good.
Canon IR 6000
Re: Canon IR 6000
Remove the Drum Unit, inspect the Drum for scratches, vacout the cleaner & the Sep Claws etc, flip the Cleaning Blade should be ok. -
Re: Canon IR 6000
Never polish the drum
Yes, the lines run front to rear of the PRINT direction not copy direction (when I copy there is no lines at all)
NOTE: These lines comes before the paper goes the the fuser unit
Thanks for helpComment
Re: Canon IR 6000
What Canuck is trying to qualify, is what direction the lines are appearing: feed direction or crossfeed. Four posts and I still don't know. =^..^=If you'd like a serious answer to your request:
Re: Canon IR 6000
Change the file format and see the results, i.e. if you it is PDF file, try TIFF, WORD, EXCEL or something else, observe and report back.Comment
Re: Canon IR 6000
Check the fuser first. I really doubt that this is some sort of image processing issue.
Most likely you just didn't notice it on copies, or the prints have more fill, making the lines more visible. =^..^=If you'd like a serious answer to your request:
