np 6545 blur copy
  • jinjangu
    • Jul 2008
    • 39
    np 6545 blur copy
    i come across few of this model, the output copy become very blur after i open and close the front cover. initially the copy is very solid after i replaced the corona wire and polished the drum. but copy become very blur when i open the front cover and close it again.
    • 23010
    I doubt there is any direct connection to opening the door. Perhaps its something to do with initial rotations....
    1) You could have a seizing developer cylinder.
    2) Possibly flat spots on the pressure roller.
    3) Check inside the lens cover that some of the tape has not peeled back, obstructing the lens movement.
    4) Chec the drum drive timing pulley. Dirt may be packed into the valleys of the pulley causing the drum drive to gallop.
    5) The upper registration roller may have flat spots.
    6) Possibly worn vertical feed clutches.
    7) The screws may have backed out of the fuser flywheel.
    8) The fuser drive clutch dries out, and vibrates loudly.
    9) The registration clutch vibrates loudly.
    10) The gear 18T on the copier body that drives the cleaning unit wears. Each tooth is worn to 1/2 thickness. (FS6-0127-000).
    All these can cause blurs. That should keep you busy for a while. =^..^=
    • jinjangu
      • Jul 2008
      • 39
      none of that causes you mention cause the problem. when i open and close the front door, the print out become blur, but after i have done some adjustment to the primary charge setting and the dev. charge setting, the print out became ok. but once i open and close the front door, the print out will be blur again. every time when i have done the adjustment to make the print out good, it will become blur again when i open and close the front cover.
      • jinjangu
        • Jul 2008
        • 39
        • Rusty old cat
          Blurry copies after door closed.
          Try turning off potential control in service mode. If That stabilizes your copies either good or bad you know where to start.
          • northerntech
            • Jun 2008
            • 69
            when you adjust the settings in service mode do they go back to where they were before when you open then close door?
            • jinjangu
              • Jul 2008
              • 39
              yes they go back to be blur when i do adjustment in service mode after open and close the door. but it is ok when i switch off the potential control, copy quality stable( but it is easy to get dark back ground if potential con is off) i tried to replace the potential sensor, but still didn't fix it.
              • northerntech
                • Jun 2008
                • 69
                okay If the machine is losing the settings you change, then you must have a battery dead on the DC Controller? i have seen this before.
                • jinjangu
                  • Jul 2008
                  • 39
                  the setting is not lost. it remain what i have set. i wonder if only malaysia,s machine has this problem. i come across few.
                  usually, when i have this problem, i will set the potential control off, this will help a little in copy quality.(but not so satisfied, cause dark back ground will appear)
                  • djbass
                    • May 2008
                    • 167
                    Its not clear exactly what you mean when you say the copies are blurred/blurry?
                    That sort of thing would suggest a problem in the optics (which is not really the case here).
                    I take it you could also mean that the images are fuzzy or feature poor quality in general, certainly a sample would help.
                    As a shot in the dark it does sound like something to do with the charge/coronas. Perhaps there is arcing somewhere between either one of the corona wires and the drum or the process unit and the drum. Maybe the DC controller is faulty.
                    Need a bit more info unfortunately.
                    No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
                    • jinjangu
                      • Jul 2008
                      • 39
                      it is bad quality in image density. as you suggest, i'll try to change the dc controllre and primary charge unit. thank you
