Error Code C-6756 in ineo +454e
    • 23007
    Re: Error Code C-6756 in ineo +454e
    With most machines now, but especially Konica Minolta products, it doesn't work to swap around boards. Replacement boards (like those from the manufacturer or Hytec) are initialized, and ready to accept data from the other boards within your machine. When you follow the procedure in the manual to install a replacement board it retrieves data from other sources (SSD, MFPB, and print controller) to "marry" the replacement board to the machine. Once "married" it will not work in any other machine, unless initialized and replacement procedure is followed again.
    Swapping minor boards like a paper size PWB will still work, but major boards will not. In many cases I've seen machines made unfixable by swapping multiple boards. You can discard this technique of troubleshooting on machines manufactured any time after, say year 2000.
    • allan
      RTFM!!
      • 5462
      My luck...
      Got the same problem.
      The trouble code history will show C-F907. The code appearing on the screen is secondary.
      C-F907 is an abort code relating to SIO Relieving port...DF
      In short the MFPB is #$%^.
      But why what toasted it?? The DF or dual scan ??
      Whatever
      • allan
        RTFM!!
        • 5462
        oops...
        SIO Receiving port
        Whatever
        • Guest
          #19
          Update solved
          Originally posted by tech51
          In my experience e301 has always been a corrupt print job. Is it connected to a network?
          no it wasn't connected to network
          Originally posted by habik
          What firmware have you flashed it with?
          What machine and type have you set when you were replacing the MFPB? and what have you got now during FW loading procedure?
          the firmware i flashed : A5C10Y0-F000-G20-J9
          during the FW update it went normale selecting the firmware and install
          Originally posted by allan
          My luck...
          that's what i was going to do change the MFPB !
          then i found in my archive MFPB Reset Tool i rest it and it worked fine and the error gone
          now the printer is working fine BUT from Code C-6756 and the printer just displays the error and the motors doesn't start > to error C- E301 > to working fine i couldn't think of any source of the problem other than detaching the wires and put them back helped to start the motors maybe !
          TO
          tech51
          habik
          blackcat4866
          allan
          Trigger
          mx6turbo89
          EarthKmTech
          copier tech
          thank you all for your replays and suggestions
          • habik
            • 2013
            #20
            Just to clarify. Do you have a printout or know the version of firmware prior to loading the G20-J9?
            There were some issues with J-series of firmware btw.
            Also, if there was previously G00-xx firmware and you have jumped over the version up firmware (G20-A9) there might be your problem.
            Byting on bits.
            Firmwares HERE
            • allan
              RTFM!!
              • 5462
              #21
              So you are saying only a board reset will fix the problem if i keep the firmware where its at?
              Whatever
                • 23007
                #22
                I'm sure that's not accurate allan. Part of the MFP board reset procedure is to reload the firmware. It can't be skipped.=^..^=
                • allan
                  RTFM!!
                  • 5462
                  #23
                  Ok .
                  Never done it before not a big board changer.
                  Makes sense a i would be wiping it.
                  I will then use 00-A9 to start with.
                  The board has been ordered so i am going to give the reset tool a try anyway.
                  Whatever
                  • Guest
                    #24
                    yes i kept the same FW only a board reset
                      • 23007
                      #25
                      Ok .
                      This might help:
                      • allan
                        RTFM!!
                        • 5462
                        #26
                        Darn no luck...
                        Tools works just fine but the board seems to be the cause.
                        Anybody with the B range and the C754 tool?
                        Will replace the board tomorrow.
                        Whatever
                        • habik
                          • 2013
                          #27
                          Darn no luck...
                          Sorry for my blond moment. What do mean by B-range?! GB4-A9 you mean?
                          Sent from my iDon't believe in marketing device using Tapatalk
                          Firmwares HERE
                          • allan
                            RTFM!!
                            • 5462
                            #28
                            What i meant was B/W's.
                            A61FFW
                            A55VFW
                            My bad they are both for B/W.
                            Whatever
                            • Synthohol
                              Certified Konica Expert
                              • Mar 2016
                              • 5824
                              #29
                              allan, do you need firmware?
                              • mx6turbo89
                                • Oct 2013
                                • 154
                                #30
                                Darn no luck...
                                Here's the C754 Tool: https://www.dropbox.com/s/jh313uwow7...145FW.TAR?dl=0
