Konica Minolta C654e Print out quality issue
  • musthafavi
    • Aug 2017
    • 76
    [Misc] Konica Minolta C654e Print out quality issue
    While printing documents color quality is not good while making copy it's ok getting original quality
    Printer Model: Konica Minolta C654e
    For your reference, I have attached herewith both copies (while printing and copying)
    So I need your kind support to rectify this issues
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: Konica Minolta C654e Print out quality issue
    in service mode print out the 4 color gradations in test pattern.
    post those scans if you can.
    • musthafavi
      • Aug 2017
      • 76
      Thanks your quick support,
      Kindly advice how can I perform print out the 4 color gradations in test pattern from service mode,
      and I am unable to access service mode, how can I access service mode I tried with stop00stop01
      Note: My printer model is Konica Minolta C654e
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Those images look like your 2nd transfer roller and possibly the transfer belt are at the end of their life.
        Load plain paper in the bypass but set it to thick 3. Force it to print on thick 3 from the bypass. If the print quality has improved it is indeed the 2nd transfer roller and belt. If there is little difference they need a new print driver or toner save is enabled.
        • mo0651
          • 1054
          Let's start with easy stuff, How old are the Drum units?? And have you cleaned laser slit glass??
            • 23009
            Use these:
            • Woxner
              • Jul 2011
              • 851
              service is stop 00 stop 01 after you do counter and details. i would look at drum age and have you ran the gradation do an inialize and reset first. if you have replaced drums then that should be done anyway.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4723
                Sorry but if you claim to be a tech then you have to at least know how to get into service mode. I'm sure if you search hard enough, even on this forum you will find way to get into service mode. Perhaps check the service manual for procedure. Would like to help but need a little more info, let's start with "touch utility key", "touch consumable life", that will show you how old drums, dev units, etc are
                • musthafavi
                  • Aug 2017
                  • 76
                  For your reference consumable life details attched
                  • musthafavi
                    • Aug 2017
                    • 76
