Need nvmreset tool for bh 224e, 284e, 364e
  • sungtaek2000@gmail.com
    • May 2016
    • 5
    Hi ..
    Does anyone has A55VFW.tar file ..?
    I have some b/w need to reset nvram.
    Please... and Thanks
    • 8144
    Re: Need nvmreset tool for bh 224e, 284e, 364e
    Originally posted by sungtaek2000@gmail.com
    Hi ..
    What do you need this software for?
      • May 2016
      • 5
      Thanks for reply..
      Cause I got c180 .. as I found it is related athentication device setting
      I tried clear and initialize settings and all but still no luck..
      So I want to try reset nvram but it is really hard to get that resetter file.
      • ventorex
        • Oct 2018
        • 1
        does anyone have this special Reset Tools firmware for the KMB C224E device?
        • Zesti
          • Jun 2009
          • 308
          Yes
          • FixStuff
            • Aug 2015
            • 16
            Sounds like there's an authentication device on. Turn it off.
            The reset tool you mentioned is used to wipe mfp board settings when installing a used mfp board. The machine settings will remain in the ssd.
            • Synthohol
              Certified Konica Expert
              • Mar 2016
              • 5824
              service mode, stop 9 set mgt function choice to unset.
              • mpadjan
                • Oct 2023
                • 2
                Hi guys,
                i too need A55VFW.tar file. The machine does not boot, if I try to update the firmware it gets stuck at MFP board updating.
                Is this thread alive, can anyone help me/us?
                ty
                • Synthohol
                  • Mar 2016
                  • 5824
                  thanks for being a contributor!
                  ck PMs
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4702
                    Originally posted by mpadjan
                    Hi guys,
                    ty
                    I've had this happen several times. Before using reset tool try firmware update selecting only MFP. This has worked for me.
                    • Rewind!
                      Somehow it works....
                      • Jan 2019
                      • 89
                      ck PMs
                      Could you provide us with the A55VFW.tar for an issue with one of our 554e models? Why our mykonicaminolta access doesn't supply this reset tool is beyond me.
                      • Synthohol
                        • Mar 2016
                        • 5824
                        done
                        • Duplicator
                          • May 2022
                          • 245
                          I have wondered that for the longest time. They give us all kinds of firmware, drivers, and other "data" files but to "officially" get that file, requires a call to KM support.
                          Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                          If I helped you out, please give me a thumbs up! It helps my reputation.
                          • jotunn
                            • 617
                            Because the official use cases are so limited that you should not encounter any conditions for its use throughout the life of the machine - that's theory.
                            But life is life, and as above - I pretend to be a service technician, encounter error CC180, and instead of disabling the authentication device I will use "Atomic Bomb".​
