Konica Minolta C454 replenish magenta toner issue
  • G6token
    • Feb 2018
    • 19
    [Dead] Konica Minolta C454 replenish magenta toner issue
  • rrrohan
    • Sep 2011
    • 1977
    Re: Konica Minolta C454 replenish magenta toner issue
    wouldnt just manually filling the dev like that upset the TCR level even more?
    • G6token
      • Feb 2018
      • 19
      • rrrohan
        • Sep 2011
        • 1977
        if you do that i do drum at same time. if the drum is pulling dev you may end up ruining the new dev as well
        • Synthohol
          Certified Konica Expert
          • 5849
          Originally posted by G6token
          The only thing I’m thinking is, the toner isn’t OEM so either it not keeping the dv unit topped up causing it hard to rotate
          you already answered yourself.
          dont skimp on the toner, thats buying a shovel to dig your own grave.
            • 23009
            I can't think of anything to add to that. =^..^=
            • G6token
              • Feb 2018
              • 19
              What do you think is a definite resolution?
                • 23009
                I think that I wouldn't have done any of the things that you did. Based on everything that I've read so far in this thread, I want nothing to do with it. =^..^=
                • Reed
                  • Feb 2011
                  • 258
                  I would have put OEM toner in it when I changed out the developer. Why make things harder on yourself. Also as stated replace the drum for good measure. Not all toner is made equally you're just asking for trouble using compatible. You may get away with compatible 9 out of 10 times but it only takes one bad one to drive you crazy!!!
                  Sent from my SM-G955U using Tapatalk
                  • Synaux
                    • Mar 2012
                    • 1224
                    First, you probably should NOT have even mentioned the toner is not OEM some of these guys are probably in the process of tracking you down to beat you with an ugly stick right now
                    Anyways, is the hopper full of toner or actually getting low?
                    I dont know if this is an issue with this model, but on some, the warning will not go away until that stupid shake the canister message appears and the TCR articles is then reset.
                    What is the TCR level reading in SM?
                    Is the image quality even affected?
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4723
                      At this point I would change the developer unit, drum & toner *ALL NEW OEM. It has to be a new DV unit to reset the voltages, etc.
                      Keep in mind "any" over life Trans belt, drum or dv unit can cause "any" color dv unit to take a dump!
                      • Woxner
                        • Jul 2011
                        • 851
                        its never a good idea to swap dev from one machine to another. the age and calibration wiil be different. in history toner shoukld be 6.6 or 6.2 % ROUGHLY you maybe pulling dev. i think there is bullitens on this.
