Biz 224 marks
  • copyman
    Owner / Technician
    • Sep 2005
    • 4639
    Biz 224 marks
    I'm getting these black marks on the page (see sample). Happening every color & b&w pages. Replaced transfer belt and didn't help. Don't see any marks on any drums. All drum are over life so I'm going to start with replacing the K drum.
    I guess this might answer my question, if you roll the paper up and put the repeat defect on top of next defect it looks to be the size of the drum, does this always mean it is one of the drums? My thought is even though I don't see the mark on drum when out of machine it only does it when operating.
    What's throwing me off is I ran single color test sheets in service mode and every color had the marks, does the black drum & developer units turn even when doing a single test page of another color?
    Wanted to add, secondary transfer roller looks good. Also like I posted the space between marks are about the size of drum which is larger than trans roll. So I ruled that out.
  • guitar9199
    • Sep 2016
    • 1100
    Re: Biz 224 marks
    If you replaced the ITB assembly, that should take the belt and drive rollers out of the equation. Check the developer roller for any marks or foreign matter... also, have you checked the transfer roller for debris?
    But yeah...don't let that drum go too much over its rated life...bad things happen to the 4 series if you get a drum that starts arcing.
      • 22999
      Re: Biz 224 marks
      That looks like a knife scar to me ... in the fuser belt or pressure roller. What is the interval in mm?
      Yes, on single color prints all developing units and drums rotate, so a fault on any of the drums will appear on every single color print, but ... the anomaly will stay the color of the drum. So if the scratch is on the cyan drum, you'll get a cyan scratch on yellow, magenta, cyan, and black single color prints.
      I don't think that your enduser can get to the drum (to damage it) without removing the unit.
      It sure would be nice if Konica Minolta put a repetitive defect ruler in their manuals, like Lexmark, Kyocera, Toshiba, Brother, Kip, and most other manufacturers. =^..^=
      • Woxner
        • Jul 2011
        • 841
        Re: Biz 224 marks
        100% its the drum
        • copier tech
          • 8131
          Re: Biz 224 marks
          If you want to be 100% sure it is caused by the K drum, you can swap it with another colour, say yellow, all you need to do is swap the chip over from one drum to the other (chip is on underside front of drum 1x tiny black screw) If the black make changed to yellow its the drum & fault if you still get the mark its not the drum.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4639
            Re: Biz 224 marks
            Thanks for the replies. Going back with new K drum & dev unit. Will post after what it was.
            • CraigW
              • Dec 2010
              • 417
              Re: Biz 224 marks
              4 series drum repetitive = 95mm.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4639
                Re: Biz 224 marks
                Turned out to be the black drum as suspected. Really weird the drum had no marks on it. Going to take apart and probably find a small piece of paper stuck in cleaning blade, etc.
