Bizhub c224e - doesn't enter Service Mode
  • GIUBOSS
    • 1436
    [Misc] Bizhub c224e - doesn't enter Service Mode
    Hi, I can't enter Service Mode by using the default "9272" x 4 times. I need to reset maintenance counter.
  • Max
    • Oct 2011
    • 561
    Re: Bizhub c224e - doesn't enter Service Mode
    Try going via reset procedure. Then stop 00 stop 01. then 9272 x4 times
    • GIUBOSS
      • 1436
      I did it... i just forgot to write it on this thread. It doesn't work and i can't enter SP mode. Maybe someone else changed "9272" password
      • Synthohol
        Certified Konica Expert
        • 5846
        did you try 9272 twice? someone obviously changed it.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4718
          maybe someone set it to the older models password, try "12345678" or "00000000"
          • rrrohan
            • Sep 2011
            • 1977
            Contact KM they can provide a reset key. I have done this in the past
            • Boltaction
              • 92
              I always change my machines from "9272x4" to 9272x2"
              • rrrohan
                • Sep 2011
                • 1977
                If your not gonna change password to something other than default i'd just turn of CE authentication. A customer can find both service mode access method and the default password in a 30 sec google search
                • GIUBOSS
                  • 1436
                  sorry but I will write in English with google transistor because I'm not with the work colleague, I hope understands me. I think from experience that by calling KM they point me to the nearest service center and usually send a technician behind payment. They don't say technical informations.
                  • copier tech
                    • 8170
                    Enter service mode from trouble reset mode this bypasses the password.
                    (hold down reset while powering on)
                    • GIUBOSS
                      • 1436
                      now I have collected all your advice. I'll be back to the customer in two days and I'll let you know. Thank you.
                      • copier tech
                        • 8170
                        Worst case use the NVRam reset firmware 🤫
                        • GIUBOSS
                          • 1436
                          Please could I have the detailed procedure and the firmware to reset the password. Regards
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4718
                            Agree try 12345678 or 00000000. I always turn off CE password. If I do want a password I change it to 12345678 same as admin.
                            Anyone who changes from one of these common passwords to a unique password is just screwing their fellow techs!
                            Although back before I started my own biz I would of liked to change all the passwords to screw a few of the A-Hole companies I worked for
                            • GIUBOSS
                              • 1436
                              i'm sorry but I try all without success, I think arrived's time to reset with the method firmware suggested here, someone knows it and can help me? Regards.
