C552 imaging units have no chip
  • mrfuser
    • 1617
    Client has a very low count c552 that is showing replace CMY imaging units. I thought we had turned off the notification before it asked for them; but it still shows up for some reason. I was going to replace the chip says the quality is perfect on them but when I took them apart there are no imaging unit chips in these imaging units . Anyone know how to turn off that message when you have this type of imaging unit?
  • copier tech
    • 8142
    Re: C552 imaging units have no chip
    The image units dont have chips from new, you say this is a low count machine most likely still have the original units.
    No need to waste money on chips, just update the firmware & change the CE mode settings as per the bulletin & no more replace IU, ITB & fuser messages.
    • Synthohol
      Certified Konica Expert
      • 5820
      there is a mini board under the front IU cover that goes to the connector underneath. thats the "chip"
      see pics here->IU 612 IU612 IU 612 Drum cartridge chip for Develop Ineo +452 +552 +652 Ineo+452 Ineo+552 Ineo+652 Image Unit Chips-in Cartridge Chip from Computer & Office on Aliexpress.com | Alibaba Group
      • mrfuser
        • 1617
        Thanks but these units have no chip as I stated in the beginning
        • copyman
          Owner / Technician
          • Sep 2005
          • 4678
          Synthohol gave you good advice and even took the time to provide a picture. Not sure what you don't understand. The connector is the chip, plain & simple. If there was no chip machine would have messg to install IU's.
          • mrfuser
            • 1617
            Hi copyman, his pic is of a standard iu chip, easy enough. Our IU (cmy) do not have a chip in them just wiring as apparently new IU have. Was just trying to see how to reset without having to go the firmware route.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4678
              Sorry I didn't look at pic. Forgot the C552 used a small circuit board as the chip. If you take cover off IU's you will see where they go. Like I said if there were no chips on IU's messg on display would say to install not replace.
              • copier tech
                • 8142
                Waste your money on chips!
                • mrfuser
                  • 1617
                  • mrfuser
                    • 1617
                    love to, but there are no original chips to replace so how would I replace them?
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4678
                      Never heard of starter IU's. Doesn't make sense because how would machine know to start the consumable counters, etc. I'm curious what you find out.
                      • mrfuser
                        • 1617
                        Please take take a look at copier tech post above
                        • kingarthur
                          • 1350
                          the original IUs never had chips, the chips were only on the 2nd set,and subsequent, I've got a feeling you may , unfortunately, have to replace the IUs, as from memory, you can't turn off the warning for the 1st set of IUs
                          • copier tech
                            • 8142
                            • mrfuser
                              • 1617
