Bizhub c35 0094 solenoid?
  • mrfuser
    • 1617
  • Albonline
    • Sep 2008
    • 1147
    Re: Bizhub c35 0094 solenoid?
    buried under the duplexing system, inside the door. fun.
    • srvctec
      Former KM Senior Tech
      • Oct 2009
      • 827
      The 0094 problem might just be that gears on that assembly are out of timing. Follow the procedure in the service manual for gettng them timed correctly. There are a number of other possibilities as well for the 0094 on these POS machines.
      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
      • Synthohol
        Certified Konica Expert
        • 5814
        0094 code articles.
        • allan
          RTFM!!
          • 5462
          Second file called 0094+error seems to be corrupt.
          Whatever
          • Synthohol
            • 5814
            yes, its corrupt online as well.
            this one is the only other one that covers something else.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4659
              Sorry wish I could be more help. Might be a waste of your time replacing that solenoid, after going through the hassle of replacing it the mach still threw the code.
              This model is exactly why Kon/Min should stick with larger machines. This model was a flop, put in same category as the PP1300 series. Most of the good Kon/Min small machines are rebranded made by another OEM, one example comes to mind is Biz 25e which I believe is made by Muratec. A very good small box. Good luck
              • Vikingrepairguy
                • Mar 2017
                • 21
                We usually just replace the door section, only thing that sucks about that is the mile long wire harness!
