Konica Minolta C284e Duplex Paper Jamming
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica Minolta C284e Duplex Paper Jamming
    Hi
    Getting paper misfeed when make double sided copy. Single prints are fine.
    Replaced the Duplex Unit, Fuser Unit and Exit Assembly but still same problem.
    Please also find the attached photo.
    Thanks for your advice.
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: Konica Minolta C284e Duplex Paper Jamming
    Please supply us with the Jam code.
    • allan
      RTFM!!
      • 5459
      What size paper is that?
      Whatever
        • 22930
        B4 is my guess. =^..^=
        • mearmi
          • Oct 2010
          • 346
          A4
          • tsbservice
            Field tech
            • 7911
            Try to replace duplex drive clutch.
            • mearmi
              • Oct 2010
              • 346
              Can u send me pick or part number
              thanks
              • Synthohol
                Certified Konica Expert
                • Mar 2016
                • 5737
                what is the actual jam code?
                does it do that on LEF as well?
                • tsbservice
                  Field tech
                  • 7911
                  thanks
                  A161M20201 Clutch
                  It's part of Main drive, near Transport motor M1.
                  • mearmi
                    • Oct 2010
                    • 346
                    Yes It does the same with LEF
                    Jam Code is: 9310
                    • allan
                      RTFM!!
                      • 5459
                      A4
                      And my uncle is a monkey.
                      How you going to get that "A4" thru that machine LEF.
                      Whatever
                      • mearmi
                        • Oct 2010
                        • 346
                        • tsbservice
                          Field tech
                          • 7911
                          Picture he posted paper is A4-R(SEF), it also jams on A4(LEF). Тhat is my understanding.
                          • blazebusiness
                            SanDiegoCopierRepair.com
                            • 1250
                            I think you might be confusing A4(letter) and A3(11x17) sizes.
                            • blazebusiness
                              • 1250
                              Jam Code is: 9310
                              There is a common issue on this series with the spring on the exit guide. You can fix it by trimming the spring a little to increase pressure.
