C360i
  • Bix
    • Apr 2018
    • 1421
    #31
    Re: C360i
    To remove any doubt, unplug it before working inside the printer.
    • kingarthur
      • 1369
      #32
      Re: C360i
      Does anyone know where the power settings are now, also, when going to the webpage, Public User Access is fine, can log in as Administrator, but everything I select, I just get a blank page, it's got the latest FW
      Cheers
      • korthr5
        • Feb 2016
        • 39
        #33
        Re: C360i
        Hello
        Utility -> Administrator -> Maintenance -> Timer Setting -> Power Settings
        • FredJ
          • Jun 2019
          • 9
          #34
          Re: C360i
          Anyone find a way to Permanently remove marketplace from the classic screen? It seems to come back with a reboot.
          • Bix
            • Apr 2018
            • 1421
            #35
            Re: C360i
            Hi, in the test machine I was able to remove it by going into the custom Widget settings. But I didn't try to turn the machine on and off. If it appears, it seems like a bug.
            Do you say that with OpenApiManager you can permanently remove?
            • FredJ
              • Jun 2019
              • 9
              #36
              Re: C360i
              I removed it from Admin-- System-- Main Menu Default Classic
              But it reappears on turning off and on
              Any other thoughts?
              I'm not familiar with this. can you provide more info?
              • Bix
                • Apr 2018
                • 1421
                #37
                Re: C360i
                Any other thoughts?
                In the settings I am sure there is a section dedicated to the panel icons.
                Now I can't remember the name of the option exactly, it should be called "widget icon customization" or something similar
                This is a tool that allows you to completely remove an application from the MFP. I don't know if it also works with iSeries.
                • FredJ
                  • Jun 2019
                  • 9
                  #38
                  Re: C360i
                  Any other thoughts?
                  when I do the above it does remove it until a power cycle then it reinstalls itself
                  I dont use widgets so that is turned off...
                  • srvctec
                    Former KM Senior Tech
                    • Oct 2009
                    • 827
                    #39
                    Re: C360i
                    Cheers
                    What web browser are you using? I had a similar issue with Firefox latest version but had to switch to Chrome.
                    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      #40
                      Re: C360i
                      Pretty sure if you disable web browser on copier it disabled all API which I imagine include the MarketPlace
                      • FredJ
                        • Jun 2019
                        • 9
                        #41
                        Re: C360i
                        Still hoping to find a solution to this..
                        • larweedad
                          • 92
                          #42
                          Re: C360i
                          Is there a way to print the config and/or test page? I can not find it in either book nor when I was searching on the copier itself or did they remove that feature?
                          • Synthohol
                            Certified Konica Expert
                            • 5847
                            #43
                            Re: C360i
                            from what i see its all gone.
                            they want you to send the list output to a usb drive.
                            haven't seen one yet and i already dislike it.
                            • rrrohan
                              • Sep 2011
                              • 1977
                              #44
                              Re: C360i
                              I just printed a list output ok
                              • tsbservice
                                Field tech
                                • 8020
                                #45
                                Re: C360i
                                Link to User manual for EU:
                                Maintenance
