C3350 vs c3351 fuser?
  • mrfuser
    • 1617
    Does anyone know if the 3351 fuser will work in a 3350?
  • Woxner
    • Jul 2011
    • 845
    Re: C3350 vs c3351 fuser?
    it should work
    • D Colour
      • Oct 2008
      • 213
      Hi
      Did you end up fitting a C3351 fuser to C3350 and did it work?
      J
      Everything that has a beginning, has an end.....
      • mrfuser
        • 1617
        Nope not yet
        • fntsy
          • Aug 2008
          • 26
          Hi, have anyone tried it yet? I want to put my good working C3350 fuser in C3351 to see if a minor wrinkling on the paper is fixed.
          • Albonline
            • Sep 2008
            • 1147
            yes.
            • emujo2
              • Mar 2017
              • 1579
              C3350 A4Y5W11, C3351 A4Y5W12..I would not try this..
              • tsbservice
                Field tech
                • 8002
                Maybe really depends on purpose but for doing some troubleshooting I would rely on Albonline's answer.
                • emujo2
                  • Mar 2017
                  • 1579
                  they are wired the same, but the connections back to the boards are different..One plugs into CN13E on the MFPB (1) the other back into PCB CN15..And they are different part # in the KM system..Normally, interchangeable parts will be numbered the same..W11 does not sub to W12..If it works let me know..Especially if one is cheaper. E
                  • fntsy
                    • Aug 2008
                    • 26
                    Reporting that the fuser fits
                    • mrfuser
                      • 1617
                      does it work without error?
                      • emujo2
                        • Mar 2017
                        • 1579
                        They both have the same life rating 105K, the W12 costs $8 less, not sure if $8 is worth the test here..E
                        • mhoward
                          • Oct 2013
                          • 9
                          It fits and works without any modifications. Just installed a used working c3350 fuser in a c3351 and it warms up and works fine.
                          • mrfuser
                            • 1617
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4664
                              Another yes vote for me. Done it several times no issues. Only difference I see is color of lock latches, new are black, old blue.
