Konica Bizhub C458 Firmware Update Problem! Please help
  • stryder
    • Apr 2014
    • 33
    #16
    Re: Konica Bizhub C458 Firmware Update Problem! Please help
    Originally posted by Woxner
    turn the machine off the hold down panel power button then turn machine on. wait for the beep then let off this will run diagnostics. also try loading k7 firmware
    and run each one seperate doing controller last. if this all fails mfp may be bad.
    Thanks, according to the diagnostics. It looks like we have a "NG" for the on board memory, picture is attached. Not sure if that prevents us from updating, would replacement one from a different machine help?
    • Woxner
      • Jul 2011
      • 854
      #17
      it will stop it. looks like you need to repl mfp. you can replace from another machine but you need to clean the mfp or swap both emmc and mfp together. if you swap both meters and other stuff wiil be from new pwb. you can cleanse the mfp and it wiil keep the machine current info.
      • copier tech
        • 8235
        #18
        Originally posted by stryder
        Hey guys, so I've run into a big snag here with the 8 series. Hope someone here may have this problem before or someone who can shed some light my way. I have the firmware R9 and W5. I tried to update the firmware on a C458 but right after the calibration finishes, it shows my all the parts ready for update, Scanner, MFP, etc. But when I've hit the button to update, everything shows NG. I've used the same firmware and same usb stick on another C458 and it updates fine no problem. I had changed the hdd and formatted but nothing is working. Any insights? Thanks in advance
        Are you updating the firmware to resolve an issue or is the machine working fine?
        Try updating the SATA firmware first there is a way to force it on after this you maybe able to install the regular firmware.
        • stryder
          • Apr 2014
          • 33
          #19
          The machine has no issues and is working fine, no problems with it. We usually like to marry the finisher to the machine with the firmware. It is a problem if this goes to a customer who wants to update the machine in the future just to find out it won't update.
          • copier tech
            • 8235
            #20
            Try the HDD firmware first then the main firmware again after.
            We've had weird issues before this update was rolled out.
            8 Series SATA.pdf
            • copyman
              Owner / Technician
              • Sep 2005
              • 4786
              #21
              Not sure if anyone mentioned this and has nothing to do with the issue in original post. I cannot believe Kon/Min left very important step in the C258-C658 service manual on how to update firmware on "8" series, about leaving front door open! You know how much time techs have wasted trying to do the right thing and "go by the book". Ha-ha problem is book is wrong! I found out the hard way few years back after wasting about 2 hours trying to load firmware "by the book".
              • Copia
                • Apr 2019
                • 10
                #22
                There is a utility that can reset your flash drive so that it can work again if you have problem flashing firmware. Most KM want the flash drive to be new in sense. If you format your flash drive using the windows format it kind of corrupt them.
                I can share the utility if you are all interested.
                • copier tech
                  • 8235
                  #23
                  Before I use any flash drive on a KM I format it in Windows first, this has always worked for me I'm updating many models daily.
                  First I click restore device defaults then start + leave the volume label blank.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4786
                    #24
                    Although Kon/Min machines are very picky with types of flashdrives I have used all kinds, never having to use a special utility to format, just tried different flashdrive. I always put the F/W on a few different flashdrives to take with me on a call in case one don't work. Think I downloaded the utility a while back and still have yet to use it. Next time I have trouble with one going to try the utility.
                    What I found to help a lot is use small GB the better. Less than 4gb is ideal. Problem is finding small gb's is difficult. Like everything else people want BIG !!!
                    • Synthohol
                      Certified Konica Expert
                      • 5910
                      #25
                      Microcenter had the best 4g flash drives, out of 20 or 30 bought i have 1 left and i use it for everything konica and it just works.
                      been through the washer and dryer many times so now its on my key chain and it stays dry but keeps working every time with just windows format.
                      i wish i knew who made them, id buy so many more.
                      • copier tech
                        • 8235
                        #26
                        These are the USB pen drives I have found most reliable & have never let me down yet 2GB ideal size.
                        USB 2.0 Memory Stick Flash Drive Swivel 64GB 32GB 16GB 8GB 4GB 2GB 1GB 1MB Lot | eBay
                        • Oystercopy
                          • Oct 2009
                          • 626
                          #27
                          I had this same issue several weeks ago on a C-258. No matter what I did, I could NOT load the f/w into the machine. It was old (G) but I tried everything listed here and more. I ended up having to send the machine out with old f/w but didn't have time to send the MFP board in to get it repaired. I think I agree with emujo, I've never had an instance where the machine didn't like the USB stick and didn't tell you so, by telling you wrong USB or cannot read. It's almost NEVER been a "type of USB" issue for me. I've upgraded several f/w since that machine with the very same stick, so go figure.
                          And I tried and tried to figure out how to do it with ISW and it was super confusing (like most of the manuals)
                          I know this wasn't a lot of help, but it is what it is.
                          OC
                          • Synthohol
                            • 5910
                            #28
                            already bought the 2g and 4g and konicas dont seem to like them regardless of how they get formatted.
                            im not spending more that 5.00 for a 4g pen drive, that's ridiculous IMHO
                            • Copia
                              • Apr 2019
                              • 10
                              #29
                              Reason why your flash drive no longer work its because your MBR get corrupted using the windows format.
                              See attached document.
                              • occus
                                • 339
                                #30
                                For me, with these instructions every USB stick works.
