logical format problem - bizhub c454e
  • levan
    • Feb 2020
    • 7
    I changed HDD on my c454e. Physically formatted new HDD (HDD is same size) and turned off machine. When i turn on there was a message "reset the encryption passphrase or format the hdd". I did encryption passphrase and restart. There was message again "reset the encryption passphrase or format the hdd". That is why I decided to format it logically. I start logical format and after 2 hour there is still 0%.
    Please help me, What I did wrong?
  • jwai
    • May 2018
    • 525
    Re: logical format problem - bizhub c454e
    On my experience, just only take logical format with a new HDD.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4886
      I have seen that before. Think I googled it and found the solution to get rid of message. If I remember correctly the google search brought me back to this forum where the procedure was. Perhaps google it or search this forum.
      • Synthohol
        Certified Konica Expert
        • 5944
        boot up, enter admin mode and it will ask to format there on the screen. say yes.
        • levan
          • Feb 2020
          • 7
          I did, I start logical format but there is still 0%.
          • levan
            • Feb 2020
            • 7
            I tried, but nothing found
            • copier tech
              • 8300
              Was this HDD new or used?
              Sound like a faulty HDD. Fit it into a USB caddy & do a scan in Windows.
              • Synthohol
                • 5944
                a colleague just ran into this, run a clear all data in initialization in svc mode, then it will format after a reboot.
                then movie data then restore address book if needed
                • femaster
                  • May 2011
                  • 1531
                  Not sure if this will help you.
                  Bulletin#11246.pdf
                  Also came across this bit of information:
                  Perform a physical format of the HDD.
                  1. Call the Service Mode to the screen.
                  2. Touch [State Confirmation] -> [Memory / HDD Adj.] -> [HDD Format].
                  3. Touch [Physical Format].
                  4. Press the Start key to start the physical format.
                  5. It stops automatically when the physical format completed.
                  IMPORTANT
                  • If [HDD Encryption Setting] is not set to "ON," when the physical format is completed and the main power switch is turned OFF/ON, a message that prompts you to set an encrypting word is displayed.
                  • If you perform [HDD Encryption Setting], after setting an encrypting word, perform the logical format.
                  6. Touch [Logical Format].
                  7. Press the Start key to start the logical format.
                  8. It stops automatically when the logical format completed.
                  9. Turn OFF the main power switch; and then turn it ON after waiting more than 10 seconds.
                    • 22994
                    The only thing that I can add is that there is a selection during the Encryption Password procedure that's not intuitive. I've had to repeat the procedure a couple times to figure out the correct choice. Sorry that I don't remember the exact wrong selection, but I've done it a couple times. =^..^=
                    • allan
                      RTFM!!
                      • 5461
                      If you don't need HDD encryption just switch it off under security setting under administrator settings.
                      Whatever
