Konica compatable RFIDeas card readers
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5841
    #46
    Re: Konica compatable RFIDeas card readers
    Originally posted by radd
    Thanks!
    That's why I keep getting the C-C180 when I try to use them with the RFIDeas reader then?
    the drivers i pointed you to are for Rf Ideas readers not ysoft.
    they should have worked.
    • radd
      • Jun 2020
      • 63
      #47
      Could it be because I didn't have the correct Product and Vendor ID's on the MFP ?
      Thanks again
      • radd
        • Jun 2020
        • 63
        #48
        well i gave you a positive rep point.
        dunno if it will reverse your red one but i had to try.
        +1
        Just returning the favor, and appreciation
        • radd
          • Jun 2020
          • 63
          #49
          Just wanted to post an update:
          LDD G00-B0 was the ticket, just needed to update the Vendor / Product ID's and build
          Everything working as it should, I can connect to the reader and am able to authenticate on my test machine.
          Only thing left is to connect the readers up to the customer machines and authenticate through AD/Papercut.
          Find out tomorrow
          Can't thank you guys enough for your all your help, glad I found this place.
          Problem now is I don't know how you're gonna rid of me, but I'll try not to bother you too much. Promise
          Off to start another thread now
          \\radd
          • tsbservice
            Field tech
            • 8019
            #50
            radd, good to know you're ahead. We have invested some time trying to help you, hope you will do that for someone else. That's the way it's for me. But i guess you exceeded expectations mate, well done.
            Just don't bother guys too much and you will learn a lot.
            • radd
              • Jun 2020
              • 63
              #51
              Will do, glad to help anyone in an way I can, no exceptions
              Hopefully the thread itself can help someone
              Thanks again for all your help
              • radd
                • Jun 2020
                • 63
                #52
                Soft switch 25 change it to B0 for latest function level.
                Also the ldd drivers are for the au-205h which is the only model for the 8 series listed by KM.
                Does set:
                Soft switch 25 to B0
                apply on the C754e also?
                Also the GW1-01 worked on the C754e
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  #53
                  Does set:
                  No, it's totally different.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • tsbservice
                    Field tech
                    • 8019
                    #54
                    Does set:
                    FW always should come with few pages doc/pdf description. It's in there. Read that carefully before put firmware on machine. Should save much of wandering and oddballs. I know i know YouTube will skip reading part but it is really important.
                      IMHO YouTube is as worthless as BSM2.
                      READ and LEARN! it'll do you good.
                      • radd
                        • Jun 2020
                        • 63
                        #56
                        Thanks guys, so much to learn
                        So soft switch 25 at 60
                        is correct for the C754e ?
                        • diedux
                          • Jan 2017
                          • 124
                          #57
                          I will try the upgrade to G00-X4 as I understand that is better for Papercut?
                          Side note.
                          Witch firmware is best for your print management solution you can check at bEST.
                          Here's the link:
                          Authorized Solutions | Konica Minolta bEST Technology Suite
                          Special for PaperCut:
                          BR
