Konica Software Switch settings (complete)
  • astanbr85
    • Jul 2017
    • 2
    #91
    Re: Konica Software Switch settings (complete)
    Originally posted by morphium
    Hi,
    can anyone tell me what 153 and 240 is (and possible values & meanings)?
    Thank you!
    I believe on an I-series machine, SW 153 this changes the colour reproduction. Hex 40 changes it to IT5 colour, Hex 00 is the default IT6 colour. I think this was covered by someone else further back that had an example attached to it as well.
    • KMFLT3CH
      • May 2017
      • 221
      #92
      Switch 153, HEX 40 on the I-series has been invaluable.
      • mitchl
        • Apr 2007
        • 501
        #93
        Bizhub C650i that wont allow a keyboard to pop up when trying to enter a IP address? You can enter Admin. but once in you cant get to the keyboard, its non-existent. Could this be some type of security done through the soft switches? There is no extra programs added and the all clear has been done numerous times, FW reloaded and the machine wont find the network on its own. Any ideas?
        • rrrohan
          • Sep 2011
          • 1977
          #94
          What is the switch to lock user settings behind admin password
          • tsbservice
            Field tech
            • 7955
            #95
            Try DIP switch 200 set to HEX 20.
            • emujo2
              • Mar 2017
              • 1580
              #96
              I know..old post..Does anyone have info on softswitch 217.. This supposedly corrects a false 100% toner issue when the bottle is empty..The KM kb article says set "DIPSSW" 217 to 0x02..I think this means set it to HEX02 but I am not 100%..
              • D Colour
                • Oct 2008
                • 213
                #97
                Emujo
                This is from Blackcat's book of tricks.
                The 8 series onwards has an engine fw dipswitch to reset toner level to 100%. If it wasnt detected when replaced.
                Everything that has a beginning, has an end.....
                • systemnova
                  • Aug 2024
                  • 20
                  #98
                  Any guesses what DipSW 189 Bit 1 does?
                  The "V2" FUM algorithm does?
                  Fumbling Under Machinery?
                  • zayonc
                    • Jan 2022
                    • 48
                    #99
                    A new software switch is implemented to change the behavior.:
                    DipSW No. 174 bit 1: Change the time of starting the next job.
                    0x00: Disable (default) - Prepare to start the next job when the last page of the previous job is fed.
                    0x02: Enable - Prepare to start the next job when printing information of the last page of the previous job is prepared.
                    • Wakawaka
                      • Jul 2022
                      • 3
                      #100
                      Hey everyone, I have a government agency that requires that the PDF version that the Konica Minolta i series sends (via email) be at version 1.5 or higher, currently the machines I've tested are at 1.4, however I do happen to have one machine in the field (C550i) that apparently sends version 1.6. (machine is out of town, haven't looked at it directly yet) KM Support said SW43 set to HEX 20 should change the version that it sends, however on every i series machine that I've tested, it won't take HEX 20. KM confirmed that this switch should change the version but they also had issues changing it on their end on their i series copier. current firmware is g00-re. Has anyone else come across this and does anyone have any insight?
                      • DeWalt_Man
                        • Jul 2023
                        • 21
                        #101
                        its not a setting issue, ironically
                        had this before, it thinks theres a keyboard installed, probs a card reader below the control panel / screen
                        • NN-GG
                          Tech-IT
                          • Mar 2024
                          • 11
                          #102
                          With new Oauth 2.0 for email, wondering why this can't show up. Not sure if this is related to the function version or Software Switch settings?
                          At C361i panel & webui:
                          "Item cannot be displayed in current settings"
                          • tsbservice
                            Field tech
                            • 7955
                            #103
                            Time to go to the MFP control panel. Not available from web connection sorry.
                            • NN-GG
                              Tech-IT
                              • Mar 2024
                              • 11
                              #104
                              I was helping the customer remotely. I was thinking I could do it by the port 50443 remote panel, but I guess that's not good enough, too. Will try it on the copier itself sometime.
