C452 Dumpster to the Rescu(r)e!?!
Re: C452 Dumpster to the Rescu(r)e!?!
i checked within the field manual, removed the just the 2nd transfer-roller an re-seated it. it is on the right-hand side machine upon opening the latch, the "middle" roller up on the spring-bearing bigger unit.(hopefully)
did not look broken, it is rolling freely:-)
picure follows as i have to leave for an customer emergency.
thank you very much:-)Comment
The roller is usually fine, it's the spring loaded post on the right side that breaks and you usually won't see it unless you lift the assy and see the while right side comes up.
Wish I had a pic.
It's the right side of the pressure cam. Rotate the cam and look for unusual movement and broken parts.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
Yeah, it's not the roller itself but the mechanism that presses it against the primary transfer belt. In my experience the rear side breaks. =^..^=If you'd like a serious answer to your request:
As a temporary, I drilled the broken off shaft #37 (coat hanger size), drilled the bracket again #37. Then epoxied in a length of coat hanger wire. I would have liked to let the epoxy cure longer, so the resulting piece wasn't quite as well aligned as I might have liked, but it was mostly indestructible. I might still have it around, someplace. =^..^=
transfer lever rear.jpgLast edited by blackcat4866; 09-29-2020, 10:53 PM.If you'd like a serious answer to your request:
Wish I had a pic.
photo_2020-09-30_17-18-45.jpgComment
[ATTACH=CONFIG]46913[/ATTACH]
[ATTACH=CONFIG]46914[/ATTACH]
as i am an r/c guy as well i do have experience with shredded wheel-hexesmy favorite cure: epoxy+ metal-rods!
hopefully my skills will be enough to give your fix a shot:-)
thank you for posting, very much appreciated!!!!Comment
Good thread to read. At least you returned us the faith that someone untrained and obviously inexperienced has the thinking and will assist to the best he can in truly respectful way. Wonderful!
Sometimes small miracles happenA tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
[ATTACH=CONFIG]46914[/ATTACH]Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
There are plenty of tricks to keep these machines running. Rebuild kits for the units.
Humor yourself and get a quote for one of the image units. Also check what a new replacement is worth.
Pricey stuff.
You might be supersized that there are plenty of them in the bin somewhere out there.
Awesome printer to have for printing tens of thousands of prints a month.
Please take pics of your repair and then print some half-tones from service mode.
Print them at 150 out of 255 and post that.
What are you going to do with the machine, home printing use?
Great of you to bring it back to use.
What is the meter count on the machine?
Check the consumable life.WhateverComment
You have an advantage on me: I had other calls to get to, and I could only let the epoxy cure ~60 minutes. You can get it aligned perfectly and let it sit the full 24 hours ... even better 48. Yes please post your results. =^..^=If you'd like a serious answer to your request:
Nice! =^..^=If you'd like a serious answer to your request:
