Office365 email scan
  • Gift
    • Mar 2011
    • 2459
    #16
    Re: Office365 email scan
    My IT guy is currently dealing with a few customers complaining about unreliable scan to mail function wih O365. Kind of every 4th scan attempt ends up with a connection error. It doesn't matter if the job contains many or just one page. Unfortunately I don't have the error codes at hand. Last case was with a C300i with latest firmware of course. Customers IT hooked up a brother MFP with he same account and no issues occured with it.
    I can recall that I had a case like this and the culprit was TCP IP v6 - once disabled the problem was gone. Unfortunately this doesn't help for the current cases.
    Anyone met this problem so far? Kinda need new input^^
    Edit: Error Code is 554
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1250
      #17
      Run a check for packet loss.
      • Gift
        • Mar 2011
        • 2459
        #18
        Yeah we performed a "-t" ping to some destinations from a clients computer with no obvious probs.
        • Max
          • Oct 2011
          • 556
          #19
          There is a technical bulletin regarding scanning to office 365. Bit sw setting, different encryption and new sertificate needs to be created. Still hit and miss in my experience.
          • Gift
            • Mar 2011
            • 2459
            #20
            I can only see a few bulletins that are a few years old and mainly for older models.
            I would guess most customers don't have any props with office 365 scan-to-mail so it's hard to guess what's really the problem if other MFB brands in the same network do not run into these occasional errors. I still have a feeling in my gut that it's some network or ISP based issue like already suggested (e.g. packet loss) and KM's controller/firmware might not be as "tolerant" compared to brother.
            Thanks to that successful brother test I can't relly refuse to investigate this further, because we kind of stand "back to the wall" and I don't like just to say "hey customer, I have no idea what's going on but the problem is still not our MFP" - so I need to work out some more solid arguments.
            I recommended my IT guy to check the customers config in our showroom and if it works here with our demo c300i (I'd guess so). After this and to rule out any "0,x percent chance for a hardware issue" he should visit the customer on site and test the MFP with a mobile pocket router and his cellphone to entirely bypass the customers IT + ISP enviroment. He also can try and ping the O365 server directly from the MFP a bunch of times.
            • copytechtrouble
              • Nov 2020
              • 100
              #21
              Originally posted by B0265
              Create a new certificate with SHA-256 encryption.
              this is the correct answer
              • Gift
                • Mar 2011
                • 2459
                #22
                Tried that via remote with no success / customer O365 scanner account works in our demo C300i. I managed to get the pocket router / mobile hot spot thingy up and running with my IT guy and we're going to visit the customer tomorrow.
                • Gift
                  • Mar 2011
                  • 2459
                  #23
                  Well what should I say:
                  We did a network parameter reset via service mode, reconfigured IP+SMTP, did several tests and now every attempt is successful.
                  • Roufi
                    • Aug 2022
                    • 1
                    #24
                    Gudnait Nelson,
                    Brat, there has been a security update regarding Secure App / App Password for authenticating MFP Devices that are routing scans through O365 and Gmail SMTP Servers. Just attended one today here in Pom. All your settings seems ok, just turn on Two Factor Authentication with your Office 365 account make sure to use an App Password instead of your regular login password. Its gonna be a Funky text of codes.
                    Cheers brat,
                    • rrrohan
                      • Sep 2011
                      • 1977
                      #25
                      the golden rules i have for office 365 are
                      Self Signed Cert with maximum encryption strength and as much validity period as it will allow
                      and
                      Disable TLS 1.1
                      i always try the domain-com.mail.protection.outlook.com first before smtp.office365.com if no advise from customer/IT.
                      the relay often wont allow scanning external so if they use MYOB scanning it will always fail with Login error.
                      if all else fails i use SMTP2Go service and just verify the sends email address is valid
                      • Ziggy
                        • Feb 2018
                        • 712
                        #26
                        Originally posted by nelo
                        Hi All, I have customer who's got a C224e and has been trying to scan to email but scans are failing. This started after they upgraded to office365.
                        I contacted their IT support to provide me the smtp address, port #, SSL / TLS details for their O365. The IT guy provided the details required with an email address and its password for authentication. After entering all the details into the machines Email TX section I still get a server connection error when a test scan to email is made.
                        I have rechecked the machines SSL/TSL version setting and is on 1.2
                        Rechecked the Email TX settings ie; port#, SSL/ TLS, smtp address, authentication details, machines IP, gateway, sub net and DNS addresses and domain name are all correct and as provided by the IT guy.
                        I can ping the the smtp address from the machine. The machines date and time is current.
                        I then uploaded a firmware and did test scan to email but the same connection error. I initialed the machines network settings and re-entered every details again but still the same issue when scan to email is tested.
                        I am thinking if there is a specific firmware for this issue, a small setting I may have over looked or is it an internal customer network issue.
                        I am out of ideas and seek some assistance to rectify this issue.
                        Thank you.
                        In 2002, SHA-2 became the new recommended hashing standard. SHA-2 is often called the SHA-2 family of hashes because it contains many different-size hashes, including 224-, 256-, 384-, and 512-bit digests.Currently the most popular one is 256-bits
                        As of January 1, 2016, Microsoft will no longer allow certificate authorities in the Microsoft Root Certificate Program to issue certificates for SSL or code signing that use the SHA-1 hashing algorithm. SHA-2 is the preferred method now.
                        The following are the incoming and outgoing IMAP server settings for Office 365.
                        Setting IMAP (incoming) SMTP (outgoing)
                        Server Name outlook.office365.com smtp.office365.com
                        Port Number 993 587
                        Encryption Method SSL TLS
                        Supported Models:
                        • bizhub 224e/284e/364e/454e/554e
                        • bizhub 654e/754e/
                        • bizhub C224e/C284e/C364e
                        • bizhub C454e_C554e
                        • bizhub C654e_C754e
                        • bizhub 227/287
                        • bizhub C258/C308/C368
                        • bizhub C458/C558/C658
                        • bizhub 808/958
                        • bizhub 4050/4750
                        • bizhub C3350/C3850/C3850FS
                        • bizhub C220/C280/C360
                        Please see attached Technical Bulletin #10310.
                        Notes:
                        1. NON-4e "Version Up firmware for MIF devices" is required to support SHA2. (bizhub C224/C284/C364/C454/C554/C654/C754)
                        You can use any of the following Special Firmware:
                        • bizhub C224, C284, C364, C454, C554 Special Firmware Version GB0-K9 Support of SHA-256 (Version Up firmware for MIF devices)
                        • bizhub C654, C754 Special Firmware Version GB0-K9 Support of SHA-256 (Version Up firmware for MIF devices)
                        • bizhub C224, C284, C364, C454, C554 Special Firmware Version GB6-K9 Support of SHA-256 (Version Up firmware for MIF devices)
                        • bizhub C654, C754 Special Firmware Version GB6-K9 Support of SHA-256 (Version Up firmware for MIF devices)
                        • bizhub C224, C284, C364, C454, C554 Special Firmware Version GB5-K6 Support of SHA-256 (Version Up firmware for MIF devices)
                        • bizhub C654, C754 Special Firmware Version GB5-K6 Support of SHA-256 (Version Up firmware for MIF devices)
                        2. Special Instructions on how to install these firmwares are provided in attached "Version Up firmware for MIF devices" document.
