C-224e: MFP Controller Download N.G.
    • 8172
    Re: C-224e: MFP Controller Download N.G.
    Originally posted by emujo2
    There is a reset tool that might help you, it may help get the machine into a state where you can enter service mode. Someone on the site might be able to provide it to you..I think if you actually have a damaged main board or corrupt SSD this may not help either. E
    I would first try updating the SSD firmware to v6.03.
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5847
      Ive see that happen after using the reset tool and not inputting the machine and type back in.
      Make sure it's not set to ff for both.
      • CP-1015
        • Nov 2020
        • 323
        I didn't use SSD reset tool. I don't understand? What do you mean with ff?
        • CP-1015
          • Nov 2020
          • 323
          #19
          I need firmware update for SSD Board (6.03) like copier tech wrote.
            • 8172
            #20
            No, you may not need the board, V6.03 firmware may help you out.
            • CP-1015
              • Nov 2020
              • 323
              #21
              That's the reason, why I wrote "firmware update". Because the issue copier has only 6.01. I tried to buy it and newest firmware for C-258/308/368, too. But I became no invoice, no BIC no IBAN so I can't sent money.
                • 8172
                #22
                That's the reason, why I wrote firmware update. Because the issue copier has only 6.01.
                V6.01 is the version with the known issue.
                If you want to try the firmware contact us at:
                Firmware Update - Printer & Copier Firmware
                • srvctec
                  Former KM Senior Tech
                  • Oct 2009
                  • 827
                  #23
                  Does your firmware not show a "Boot Rom" button right next to the "Start" button on the touchscreen before starting the actual update of the F/W? It should and if it does, just tap "Boot Rom" to update to the latest SSD version F/W. I got into the habit of just doing that on those older machines when the new SSD F/W came out so I could make sure it had the latest. It won't update automatically, so you have to press the touchscreen button to initiate the process. If it already has the latest, it will just indicate that on the next screen and not update.
                  Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                  • CP-1015
                    • Nov 2020
                    • 323
                    #24
                    I tried to buy it and newest firmware for C-258/308/368, too. But I became no invoice, no BIC no IBAN so I can't sent money. I have sended 7 board mails to you!
                      • 8172
                      #25
                      OK.
                      Please contact us at sales@copierfirmware.co.uk
                      The message system on copytechnet has proven to be a little unreliable.
                      • CP-1015
                        • Nov 2020
                        • 323
                        #26
                        OK.
                        Ah, ok, who answers ober message system on copytechnet, not you? You want to make jokes with me?
                          • 8172
                          #27
                          The message system on here gets very cluttered if you have multiple replies, we prefer to exchange correspondence via email.
                          • CP-1015
                            • Nov 2020
                            • 323
                            #28
                            [ATTACH=CONFIG]48572[/ATTACH]
                            IBAN is wrong. And I need firmware for C-258, too.
                              • 8172
                              #29
                              Thanks, but in future please contact us direct via email.
                              • CP-1015
                                • Nov 2020
                                • 323
                                #30
                                Ok, thank you very much. I'll do!
