C-224e: MFP Controller Download N.G.
Last edited by copier tech; 03-11-2021, 10:41 PM.Let us eat, drink, and be merry, because tomorrow we may die!
Re: C-224e: MFP Controller Download N.G.
Ive see that happen after using the reset tool and not inputting the machine and type back in.
Make sure it's not set to ff for both.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
I need firmware update for SSD Board (6.03) like copier tech wrote.Comment
That's the reason, why I wrote "firmware update". Because the issue copier has only 6.01. I tried to buy it and newest firmware for C-258/308/368, too. But I became no invoice, no BIC no IBAN so I can't sent money.Comment
If you want to try the firmware contact us at:
Firmware Update - Printer & Copier Firmware
Does your firmware not show a "Boot Rom" button right next to the "Start" button on the touchscreen before starting the actual update of the F/W? It should and if it does, just tap "Boot Rom" to update to the latest SSD version F/W. I got into the habit of just doing that on those older machines when the new SSD F/W came out so I could make sure it had the latest. It won't update automatically, so you have to press the touchscreen button to initiate the process. If it already has the latest, it will just indicate that on the next screen and not update.Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.Comment
V6.01 is the version with the known issue.
OK.
Please contact us at sales@copierfirmware.co.uk
The message system on copytechnet has proven to be a little unreliable.
Screenshot 2021-03-12 091114.jpgLet us eat, drink, and be merry, because tomorrow we may die!
