bizhub 558 buzzing near the bridge unit.
    • 23010
    It was simple to key the bridge cover and see that the noise was coming from the exit section, not the bridge.
    Manually turning the gears from the exit drive, I can catch the exit timing belt jumping ... so I pulled out the exit section, and it looks like this:
    The pulley driven by that timing belt seems to have ovalled out the frame, where the shaft passes through, loosening up the belt. The other bores seem to be intact, not-worn, so I thought maybe an oil impregnated bronze bushing might do the trick, like this:
    It's nice and quiet now, and if that 6mm bushing ever shows any wear, it's a small matter to swap it out. =^..^=
  • Synthohol
    Certified Konica Expert
    • 5908
    Re: bizhub 558 buzzing near the bridge unit.
    your MacGyver skills are on point man, that took my breath away.
    really a work of art.
    • tsbservice
      Field tech
      • 8064
      +1. That bushing should be installed at factory line.
      BC mastery is beaten only by his humility.
      • kingarthur
        • 1390
        [ATTACH=CONFIG]49140[/ATTACH]
        [ATTACH=CONFIG]49141[/ATTACH]
        Yep...I had that, did exactly the same thing
          • 23010
          I wouldn't be a bit surprised if a bulletin comes out to this effect. =^..^=
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            Nice fix! What was the total count on that machine?
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
              • 23010
              225K ... not much. That's mainly why I did not order another inferior plastic piece. =^..^=
              • tulintron
                • Jul 2014
                • 668
                +2 Excellent idea
