C4050i power save settings
  • copyman
    Owner / Technician
    • Sep 2005
    • 4762
    I have pwr save set for 240 mins but screen goes black after 1 min. Looked through admin & service menus several times and didn't see it, unless I missed it? Is there a way to change display to stay on longer? Thanks in advance
  • Synthohol
    Certified Konica Expert
    • 5891
    disable screensaver?
    • copyman
      Owner / Technician
      • Sep 2005
      • 4762
      I didn't see anything like that in menus? Ha-ha wish it was that easy and hope I just missed it. Maybe a soft sw can hide tab?
      • Ziggy
        • Feb 2018
        • 801
        Once in admin mode there is a search option. If you search screen saver it will link you to it, if the machine has it
        • Ziggy
          • Feb 2018
          • 801
          I would also turn off sleep mode. Konica Minoltas sometimes have trouble coming out of sleep mode. to do this first in service mode system 1 look for sleep on/off permit and set to allow. Then in admin mode on same screen as lower power you will see a check box to disable sleep mode
          • KMFLT3CH
            • May 2017
            • 242
            Sounds like the marketplace screen saver is kicking on. Try to disable it under Admin > System Setting > Reset Settings > System Auto Reset > Screen Saver toggle to OFF.
            If you dont see the screen saver option there that means the machine's firmware is too new, G00-E9 or higher removed that on/off option.
            I just disable that marketplace crap entirely... Admin > network > IWS > Marketplace > toggle OFF - that will also nuke the screen saver
            And some settings I recommend doing on all i-series machines:
            Admin > maintenance > Timer setting > power settings:
            Low power mode = 60-120min
            Sleep mode = OFF
            Power Consumption in sleep mode = Disabled
            Enter power save mode = Normal
            Awake from PS/Control panel = On, +2
            • rrrohan
              • Sep 2011
              • 1977
              if you dont use market place id set soft switch 172 to hex 01 then via admin go disable it.
              i have users who have a mix of papercut and sharepoint, screen goes black but not off after 1 min as a result of enabling marketplace to use sharepoint.
              one user suggested installling the weather app so it atleast shows some useful info but unlike the old days u cant disable screen saver. i used to use api manager to remove it but im pretty sure it just reinstalls itself
              • ba321
                • May 2025
                • 8
                U mnie ustawienie soft switch 172 na hex 01 bardzo pomogło.
                Ale mam inny problem.
                Po normalnym wyłączeniu ekranu maszyna uruchamia się ponownie. Oto przykład: ustawiam tryb oszczędzania energii na 5 minut i uruchamia się ponownie po 5 i 10 sekundach, czasami po 6 lub 10 minutach. Co się tu dzieje? Czy czegoś szuka? Jakiegoś ustawienia sieciowego lub faksu? Ma wyłączony faks .
