Panel Freeze i-Series
  • Konicaboy
    • Oct 2020
    • 4
    Hello everyone
    We have had a problem with the panel on the new i-series for a few weeks now. It freezes.
    On some machines we were able to fix it with the new firmware (G00-RB). Now I have a c450i on which I have already installed the new firmware (machine) and (panel) without success. Then a new panel was installed, and after two weeks it froze again. Now the CPU has also been replaced, without success.
    Does anyone have the same problem or a solution?
    Many thanks and best regards
  • Jumping Jack Flash
    • Jul 2009
    • 66
    All you have left is the SSD drive to replace, a typical symptom in the "i" series
    • Don N.
      • Nov 2011
      • 409
      Did you repartition the storage board using 0548216 then do data recovery? See bulletin 13472 attached for t/s i series hangups.
      • copier tech
        • 8174
        Originally posted by Konicaboy
        Hello everyone
        We had the exact same issue. Try this SW159 HEX 08 setting it stops the SSD from sleeping & it resolved the issue for us.
        • Don N.
          • Nov 2011
          • 409
          This comment is pobably not your issue, but relevant for others. We had two i series panels with issues. One blinking out and one dark no power. Both were the new usb-c connector. Just reseated the connector & fixed.
          • Duplicator
            • May 2022
            • 246
            There is also a panel firmware update that fixes freezing. Only applies to some serial numbers though.
            Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
            If I helped you out, please give me a thumbs up! It helps my reputation.
            • Ziggy
              • Feb 2018
              • 780
              did you update function level (sw25 to hex 04) when you updated to G00-RB and did you update the boot rom when you updated firmware? I believe the bulletin Don N. posted has instructions on how to do it
              • rrrohan
                • Sep 2011
                • 1977
                on the 8 series i had a lot of problems with the menu screen randomly not responding and sometimes if have to press utility button like 6 times before it would register
                new panel never fixed it
                it was always resolve with a full system initialization
                • tsbservice
                  Field tech
                  • 8020
                  One minor correction maybe it's typo but Sw 25 should be 40 not 04.
                  • Ziggy
                    • Feb 2018
                    • 780
                    Thank you for catching that . you are correct
                    • Boyaka1989
                      • Mar 2021
                      • 19
                      goodday
                      how do stop the SSD exactly ?
                      sw 159
                      bit 00001000
                      hex 08
                      this is how it was set .
                      • menon
                        • Sep 2017
                        • 2
