C3351 Error c-6751
  • Massimiliano
    • Oct 2019
    • 48
    C3351 Error c-6751
    Good morning everyone,
    I have error code c-6751 on 2 machines, can anyone give me a tip on how to resolve it?
    Thank you
  • Larhal
    • 584
    Do you have a service manual? the answer is in there.
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      try this
      Field technician since 1994
      • Massimiliano
        • Oct 2019
        • 48
        yes I checked the manual...
        I was wondering if anyone had had this problem and if there was an alternative solution, it seems strange to me that both machines have the same problem at the same time.
        Thank you
        • elmaligno
          • Oct 2009
          • 302
          The flat cable that goes to the scanner is often pinched and broken due to a design flaw, this may be the cause.
          • 4Toon
            • Mar 2023
            • 112
            Konica no longer sells the scanner unit to replace it unless you have a stock pile or used ones. one fix that works sometimes is by adding a 1mm spacer on the rail under the slit glass closest to the back of the mfp
            Permanently banned from Konica SSD.
            • Massimiliano
              • Oct 2019
              • 48
              Thanks for the tip, I'll try to see if it works.
              the strange thing is that after picking one up and taking it to the laboratory, the defect no longer appeared.
              • femaster
                • May 2011
                • 1514
                As was already stated, it's a good chance the ribbon cables are the issue. It's a common problem with these machines.
                Be forewarned, if you mess with the ribbon cables you probably will end up replacing them. They are super cheap quality and just removing the end from the socket on the main board can cause the conductive trace(s) to peel off the cable. I can't tell you how many parts machine we have because they weren't worth fixing after an attempt was made to fix the brittle and cracking exit unit guide plate and a trace peeled off the scanner ribbon cable during it's removal.
                I just fixed a C3351 last week. It was throwing a C9401 - Exposure Lamp Lighting Failure. Swapping just the scanner/CCD assembly didn't fix it. I ended up pulled the entire scanner assembly off of another machine. Even after removing the ribbon cables as carefully as possible, there was still one trace that pulled away from the cable. Thankfully it didn't rip it completely off and I was able to press it back down. I inserted the cable end into the socket at an angle and by some miracle it worked afterward.
                • Woxner
                  • Jul 2011
                  • 851
                  this is the new ribbon # A93EN11412 i had one today. you might want to get the end connectors A7AHM9000 X 2
                  • Todd Glenn
                    • May 2021
                    • 22
                    Have had to replace 5 ribbon cables, and one cis or for these same codes on de machines. Definitely order the two end connectors ordered above ,for each cable.
                    • Sandoval
                      • May 2018
                      • 12
                      Did you fix this error by adding a spacer?
                      • Massimiliano
                        • Oct 2019
                        • 48
                        Hi, unfortunately not, then the error 9401 also appeared on the machine.
