Finally new firmware series i
  • and
    • Oct 2011
    • 99
    Finally the G00-RD firmware fix 0x1FFF/0x2201900000000100 code.
    Will save some cpu? ?
  • kingarthur
    • 1385
    Are you talking about the 5732 error, overheating CPU - that was in the FW before, GG1-RB
    • tsbservice
      Field tech
      • 8052
      No he's talking about machine freezes and many 0x1FFF in detail code history eventually solved with new CPU board.
      • elmaligno
        Expert technician KM
        • Oct 2009
        • 302
        G00-RD
        2.3. Fixed issues
        1. C5372 (CPU temperature failure) may occur during PC printing or low power/sleep mode.
        As a countermeasure, the FAN will not turn off even in low power mode or sleep mode after applying this firmware (GG1-RB).
        For the customer who prefers to stop CPU FAN, it is required to set the following software SW to disable the countermeasure.
        ??A function to turn ON/OFF the CPU FAN during low power and sleep mode.
        ???Software SW No. 189 (bit7)
        ???Hex: 00 (Enable [default]) FAN is turned ON in low power/sleep mode.
        ???Hex: 80 (Disable) FAN is turned OFF in low power/sleep mode.
        *Please refer to PSKM_BT2411102EN for more details
        2. MFP loses the connection to WWRSPF after executing Setting Data Import with Json type
        *Please refer to PSKM_BT2411254EN for more details
        3. MFP freezes when printing via AirPrint or printing PDF file saved in USB flash drive from Chrome version 122 or later.
        *Please refer to PSKM_BT2411583EN for more details
        4. A machine reboots with detail code 0x1FFF/0x2201900000000100
        *Please refer to PSKM_BT2317698EN for more details
        5. "Complete" button is grayed out when printing in Custom Size with firmware version G00-RB or later.
        *Please refer to PSKM_BT2413518EN for more details
        Field technician since 1994
        • and
          • Oct 2011
          • 99
          Yes elmaligno.
          This mfp after over 1000 reboots can work in peace with the G00-RD firmware
          ?immagine.png?
          • femaster
            • May 2011
            • 1519
            Still nothing showing for this firmware version on the Konica US website.
            • tsbservice
              Field tech
              • 8052
              Don't worry about that still when I had access to MKM they had loads of useful information compared to our latest and greatest KIKU...sigh ?
              You need anything I can help with just send me PM.
              • Massimiliano
                • Oct 2019
                • 48
                Good evening,
                I confirm that with the new firmware the problem of continuous resets on the C300i has been resolved!
                • copier tech
                  • 8200
                  Still waiting for this release in The UK.
                  • Black Cloud
                    • 176
                    Still awaiting this firmware release in Canada.
                    Net+ PDI+ @Remote
                    • SAR
                      • Jul 2009
                      • 205
                      We just got G00-RE here in US, no GOO-RD.
                      Fixes the C5372 code if you set software sw 159 to hex 80.
                      • Black Cloud
                        • 176
                        Thanks, Sar.
                        It's time to try to stop the CPU BBQ.
                        Net+ PDI+ @Remote
                        • Wakawaka
                          • Jul 2022
                          • 3
                          KM Support keeps telling me to use GC4-RB to correct the issue instead of replacing the CPU. Item 14 on the readme shows "14. A machine reboots with detail code 0x1FFF/0x2201900000000100" I do know that I've replaced A lot of CPU's lately which definitely fixes the issues. Hopefully special firmware this fixes the issue as well. We are updating (especially on machines out of warranty) and are monitoring them for any further issues (client reported or in the list prints). As this is special firmware, my question is whether we should ever or never update the firmware on the machines that are affected by this cpu issue? Would updating the firmware in future basically replace the special firmware and then we have problems again?
