Bizhub C458 LCT PC415 tray
  • Reed
    • Feb 2011
    • 259
    The cable for the lift tray (PC410/PC415) has been pinched and now the tray isn't lifting properly. Has anyone replaced the cables on the these trays? It doesn't look like it can be done easily and it seems to happen frequently with these trays
  • copyman
    Owner / Technician
    • Sep 2005
    • 4623
    I just posted about why the rear cable jumps off pulley. Search the posts in last few weeks. There is a small round part called the damper, this allows the tray in drawer to lower slowly. If this is bad the tray will drop hard (especially with full paper) and cable comes off rear pulley. It's like a $5 part
    • Ziggy
      • Feb 2018
      • 692
      It is a damper , the parts manual calls it a dumper
      A2XM623000 Dumper
      • copyman
        Owner / Technician
        • Sep 2005
        • 4623
        A2XM623000 Dumper
        That's what I posted in another thread but great you added part #.
        • Reed
          • Feb 2011
          • 259
          Thanks for the input and the part number.. I hadn't given it much thought about the tray dropping so fast. But now it makes sense
            • 22997
            The ridges on the edge of the lift cable drum are not very tall. It's common for the cable to slip over the side of the drum, and wrap onto the shaft. Some of us have cut heavy mylar disks with a hole for the shaft, cut a slot to slide it over the shaft without disassembly, then apply two sided tape to the disk on the side that will stick to the drum. Did I explain that clearly? You're creating a raised ridge on both sides of the drum, so the cable doesn't slip off the edge.
            It works. =^..^=
