C368 ResetTool a789be.tar
  • Jinn
    • May 2023
    • 137
    Just want to confirm that the reset tool "a789be.tar" is common for every colour 8 series ? or there is separate tool for every model?
  • aberock
    • May 2022
    • 129
    Originally posted by Jinn
    yes work on any 8 series
      • 8200
      IS there a tool for the i series available ?
      • tsbservice
        Field tech
        • 8052
        Yes.
        • Ziggy
          • Feb 2018
          • 802
          the 789.tar file also works on i-series
          • Jinn
            • May 2023
            • 137
            But this one is not working.
            Machine is not taking any firmware neither reset tool
            • Jinn
              • May 2023
              • 137
              Not working. May be board is faulty
              • aberock
                • May 2022
                • 129
                what error message you get ?
                • Jinn
                  • May 2023
                  • 137
                  The error was C-D011 Sata controller.
                  HDD replaced but still same. then tried disabling the HDD, again C-D072 error code. When HDD enabled machine freezes after sometime.
                  I have those firmwares for repairing sata controller errors but machine is not taking firmware. No error shows machine just starts normally.
                  • aberock
                    • May 2022
                    • 129
                    this problem can be solved by update SATA FW. CD011 . the fw is different from machine fw .
                    its not the hdd or mfp board problem .
                    • Jinn
                      • May 2023
                      • 137
                      Then why is it not taking firmware?
                      • Ziggy
                        • Feb 2018
                        • 802
                        Machine may not like your usb stick, try using different usb stick or format it with the hp formatter tool. HP formatter tool can be found on Konica Minolta site or I can email it to you
                        • Hansoon
                          • Sep 2007
                          • 3391
                          The HP USB Disk Storage Format Tool allows you to format a USB Flash drive too FAT, FAT32, and NTFS file systems. It also allows you to create a DOS startup disk, but this is not very useful with modern versions of Windows.
                          Hans
                          • Zesti
                            • Jun 2009
                            • 309
                            Trying to reset a c368e with reset tool. It completes successfully but CE password does not convert to default. Any help pl.
                            • Synthohol
                              Certified Konica Expert
                              • Mar 2016
                              • 5892
                              is the machine and type correct?
