3070L bad cyan
  • nullskull
    Learning
    • Aug 2023
    • 424
    3070L bad cyan
    Got some blue splotches showing up on prints occasionally. Opened up the transfer belt unit and found this. Guessing it's a bad cyan dev unit?
  • lartis.aineias
    • 78
    Replace the Cyan developer unfortunately it is the only solution!
    • Albonline
      • Sep 2008
      • 1148
      overtone on cyan. what's the life count look like?
      • nullskull
        Learning
        • Aug 2023
        • 424
        Seems to be very low to me. dev was changed only a couple months ago.
        Edit: we have a tech who came in to do it last time (I'm not exactly a tech just the in house employee working on the machines the most) and I have a suspicion he didn't run the adjustment procedures and just mixed in a little toner when reinstalling. I wasn't there so I don't really know. Possibly that is why it's overtoning cause it wasn't set up properly?
        • Andrey51
          • Feb 2024
          • 6
          A cover of a developer unit has holes for ventilation. Sometimes they become clogged, a ventilation is impaired, and a developer unit unit becomes dusty. Try removing that developer unit cover and vacuuming this holes.
          • wjurls
            • Feb 2017
            • 496
            This here, the cyan suction vents are clogged. Clean the ports shown above and also the suction ports in the back behind the drum carriage. Also if it has been ignored, replace the filter box.
            • nullskull
              Learning
              • Aug 2023
              • 424
              Thanks for your help!
              • nullskull
                Learning
                • Aug 2023
                • 424
                BTW vacuuming the holes fixed the issue. Just thought I'd mention it in case others also have similar issues with this model.
                • Ziggy
                  • Feb 2018
                  • 722
                  Like wjurls said you don't want to ignore the toner filter. If this filter goes to far past life you will start having major issues . Production machines are unlike office machines. they can bite you hard if you try to run consumables much past life
