Printing Quality Issue
  • maddy4u
    • Feb 2010
    • 19
    Please looks in to the attachment & suggest possible remedies
    This gallery has 1 photos.
    • 23007
    It might be pertinent to know what make/model that you are working on.
    • maddy4u
      • Feb 2010
      • 19
      thanks for your reply. its Konica C454e
      • Synthohol
        Certified Konica Expert
        • 5822
        whats the life on the DV unit?
        do all colors act the same?
        way more info please.
        • femaster
          • May 2011
          • 1500
          It's hard to say, but it looks like there is Cyan streaking on that magenta print. Might help if you were to post a half-tone from each of the colors. Run then at a reduced setting of like 128 instead of 255.
          • tsbservice
            Field tech
            • 8007
            Swap colour drums to see if it makes any difference. We are copier nerds NOT copier gods.
            Next time post more than one simple picture.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4679
              With the 4 series 99% of the time it comes down to the drum(s) or developer(s) as the issue.
              • maddy4u
                • Feb 2010
                • 19
                Thanks for your reply. yes all colour have issue except yellow. dv unit re manufactured with original developer power. swap drum unit still problem is same
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4679
                  What original developer powder? Only developer powder I know of is aftermarket for 4 series. I guess you are using aftermarket toner & drums as well?
                  • maddy4u
                    • Feb 2010
                    • 19
                    yes
                    • tsbservice
                      Field tech
                      • 8007
                      yes
                      Good luck then and bye.
                      • dibyendu2008
                        • Dec 2011
                        • 27
                        Aftermarket consumables are not reliable and you cannot get satisfactory output with aftermarket consumables.
                        • Tech09
                          • Apr 2020
                          • 145
                          Without knowing the age of the drums and developer units I would say replace all of them and also make sure you clean the laser lenses below the drum units. If, after replacing everything and cleaning the laser lenses, you still have a lighter image on the sides you might want to pull the laser unit itself and clean the hexagonal mirror. They can sometimes build up a white powder on one side of each face of the mirror.
                          • Gift
                            • Mar 2011
                            • 2459
                            I think this looks not bad considering everything is sourced from aftermarket stuff, the cheapest solution would be adjusting the "expectation management".
                            I also agree that cleaning the laser glasses/optics/polygon mirror might help to reuce the lighter density on the side. A worn out transfer belt also reduce the image quality, usually visible in irregulations/lines that are visible across different colors (use 100/255 full bleed halftone tests).
                            • 4Toon
                              • Mar 2023
                              • 112
                              Yellow would be hard to see this issue on. either belt or drum. if you put your yellow drum in cyan and it still looks the same as the original cyan drum I would look at a new belt. lightness could be the laser like stated above.
                              Permanently banned from Konica SSD.
