"original has been left on the glass"
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 298
    Hello everyone. A recurring problem. C308, the machine indicates “an original has been left on the glass”, and also any original you put on the glass it reads it as A3.
    I have cleaned all the mirrors and the glass top and bottom, changed the size sensor next to the CCD, the ADF close detection sensor behind the operator panel, changed the main and side scan register setting, but it doesn't work.
    Other times I have had some of these components fail but not this time.
    I still have the CCD and the scanner with the lamp.
    Any suggestions?
    Thank you.
    Field technician since 1994
  • copyman
    Owner / Technician
    • Sep 2005
    • 4551
    Thought there was an adjustment for that?
    • kenpio
      • Dec 2015
      • 199
      I have always cleaned the underside of the glass and the mirrors for that, real good and it goes away after that. I see that you have done that.
      • tsbservice
        Field tech
        • 7929
        I will redo ADF setup next check scan area settings and maybe compare with another similar machine.
        • copier tech
          • 8107
          I've had marks on the DF white board cause this issue, make sure this is spotless.
          • Woxner
            • Jul 2011
            • 829
            98% of the time it's the height adjustment. Reset of time just the glass
            • Ziggy
              • Feb 2018
              • 687
              Haven't had this problem on 8 series but on i-series I have ran non-image area erase adjustment to resolve this problem
              • elmaligno
                • Oct 2009
                • 298
                thanks to all, the problem was the ccd
                • BR549
                  • 109
                  I agree with Woxner. I usually fix this by lowering the right side of DF if cleaning the glass doesn't fix it. That way it activates the angle sensor sooner and doesn't see the platen cover as paper.
