ADF Noise with bizhub 450i
  • JasonSBE
    • Apr 2014
    • 186
    I've got a noise coming from the CIS cleaning system. When M7 engages to clean the CIS, it's making a consistent rapid clicking sound. We have tried changing the cleaning system, but the sound persists. Has anyone else ever had anything like this happen? Any guidance would be greatly appreciated.
  • Albonline
    • Sep 2008
    • 1151
    does it sound like a cog belt popping ?
      • 23009
      That was my first thought.
      • JasonSBE
        • Apr 2014
        • 186
        Not sure what a cog belt popping sound like. I took a short video with the cover off.
        • Tech09
          • Apr 2020
          • 145
          Don't have a manual at hand currently, but can that motor be run in the Load check? From the vid I don't think it's the CIS cleaning motor, it is a short vid so it's hard to really see what's going on.
          • SAR
            • Jul 2009
            • 203
            Any luck fixing this? I have the identical noise on one of those feeders and having a hard time finding the cause.
            • Synthohol
              Certified Konica Expert
              • 5842
              does it do it in scan as well?
              if you select a higher DPI i think the scan process slows a bit and you may be able to see something if the chatter noise slows as well.
              i would also look very closely for a wayward paperclip near all belt paths, the noise is familiar but that was over 3 years ago last time i heard it in person
