I've got a noise coming from the CIS cleaning system. When M7 engages to clean the CIS, it's making a consistent rapid clicking sound. We have tried changing the cleaning system, but the sound persists. Has anyone else ever had anything like this happen? Any guidance would be greatly appreciated.
ADF Noise with bizhub 450i
Not sure what a cog belt popping sound like. I took a short video with the cover off.
I've got a noise coming from the CIS cleaning system. When M7 engages to clean the CIS, it's making a consistent rapid clicking sound. We have tried changing the cleaning system, but the sound persists. Has anyone else ever had anything like this happen? Any guidance would be greatly appreciated.Comment
does it do it in scan as well?
if you select a higher DPI i think the scan process slows a bit and you may be able to see something if the chatter noise slows as well.
i would also look very closely for a wayward paperclip near all belt paths, the noise is familiar but that was over 3 years ago last time i heard it in personWe know a thing or two because we've seen a thing or two.
The medication helps though...Comment
